i didn't know serpentine belts could slip!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Jul 8, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i didn\'t know serpentine belts could slip!!
    mine slipped when i started the sub and turned the new A/C on. it only does it for a few minuites, though. is my belt bad? /forums/images/icons/confused.gif /forums/images/icons/shocked.gif
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Re: i didn\'t know serpentine belts could slip!!
    Are you sure it's slipping, and not squealing?
  3. bklynlifted
    bklynlifted 1/2 ton status
    Feb 4, 2002
    261
    brooklyn ny home of the brave
    might be to tight?? /forums/images/icons/wink.gif
  4. muddysub
    Jun 23, 2001
    10,451
    489
    it goes SSCREEEEEETCHHH!!!!!! that's slipping right? how can it be too tight it's spring loaded self adjusting. /forums/images/icons/confused.gif
  5. bklynlifted
    Feb 4, 2002
    261
    my 88 has 1 serpintine belt that is for the alt and you can over tighten that one. i didn't know you had a single belt set up, my mistake, break out the old bar of soap, and see what happens. /forums/images/icons/wink.gif ps check to make sure your new a/c has the same amount of grooves on the pulley as your old one??
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds to me more like a case of something not quite right with your a/c compressor. /forums/images/icons/mad.gif It takes a lot of resistance to make a serpentine belt slip. When the alternator seized up on my S-10 a few years ago, the belt had enough grip to stall the engine once it came back down to idle. /forums/images/icons/shocked.gif The starter couldn't move the engine until I removed the belt.
  7. muddysub
    Jun 23, 2001
    10,451
    489
    the a/c compressor is new, and it only did it once hasn't done it since. hmmm, i guess the parts were just talking to eachother. /forums/images/icons/confused.gif
  8. XCUATRO
    XCUATRO Registered Member
    Jul 4, 2002
    31
    so. cal.
    I think my sub "1989" made the same noise, the day after I had the engine steam cleaned.I thought my AC had gone out but later guessed-figured it was the factory belt tensioner pulley.? A local shop told me to have it replaced,because of my high milege /forums/images/icons/confused.gif
  9. muddysub
    Jun 23, 2001
    10,451
    489
    hmmm, i have 155,000mi on mine. should i look at replacement?
