I discovered my blazer sits crooked!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by english_bloke, Oct 30, 2001.
  1. english_bloke
    english_bloke Registered Member
    Oct 5, 2001
    22
    Just moved from England to the States
    Whilst I was walking from the grocery store to my blazer, I discovered the right side sits lower than the left side. I thought possibly it was just the rear so I walked around and looked on from the front and it indeed is also sitting lower on the passenger side. So, last night I looked all over it and found a bend in the frame! The frame is made of metal shaped in a 'C' as you know, and the bottom lip (as I shall call it) is bent down in one spot. Would that be of concern to me? Or would the suspension cause it to sag on one side? Shall I fix that small bend?
    Cheers,
    The English Bloke
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Where is this "bend" in the frame? I have seen frames fresh off of the showroom floor that have areas of the lower frame rail bent downward. More than likely your lean is caused by bad body mounts, or possibly the springs have sagged more on that side than the other. Just a thought.
    '85 K5 : Run it til it breaks, then fix it and go again!
  3. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    137
    Rhode Island
    You can also check for broken leaves. Before I changed my springs, my truck sat lower on the drivers side and it turned out to be a broken leaf. May not help you, but it's worth a shot.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    488
    Grand Rapids area
    This is not an uncommon problem. It may be unrelated to the frame issue you spotted. For some reason Blazer don't seem to settle evenly with time. Check all four springs and the body mounts. It's also possible that the truck has been in an accident and is no longer quite true. You could have a friend drive along behind you and see if it dog-tracks.
    <font color=green>There's nothing like the smell of a rich V-8 in the morning...</font color=green>
  5. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    See if the body is lined up with the bumpers. If it is not lined up with the bumper its prolly your mounts.
    350FI/700r4/NP208c/10b's ORD 4" Shackle Flip/ORD Disconnects
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Some ideas to check:
    Rubber body mounts. Swap for polyurethane mounts.
    Broken or sagging leaf springs. Repair or replace.
    Low tire pressures. Check and fill up to match others.
    Spring bushings could be shot. Install new bushings, preferrably polyurethane.
    I have not seen a 'bent' frame cause a truck to sit uneven except for a very badly bent one. Those with a slight bend should not affect the stance of the vehicle.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
