i don't have a high idle on my 6.2...
Discussion in '1982-Present GM Diesel' started by colbystephens, Mar 27, 2007.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    what's up with that? how do i get a high idle. i'd like to have a high idle on start up.
  2. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    i disconected mine, cuz it would rev way to high. it was start out fine but after like 2 mins it would go to redline.
  3. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    There should be a solenoid on the Inj pmp. When energized due to coolant temp - it has a plunger that hits the throttle plate. It should have one wire going to it.
  4. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    Which sensor does it use, where is it at on the engine?
    George
    to lazy to go out and look
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    agreed. i'd like to know what all the different electrical connections do - i only ahve one hooked up and it runs like a champ (the pink IP wire isthe only one hooked up)
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    Pretty sure the temp inhibit switch is on the drivers side head, right next to the vacuum pump. Once the switch sees 120F or so the cold advance should kick off.
    Rene
  7. mstockton
    mstockton Registered Member
    Apr 20, 2007
    99
    California
    Depends on the year I think. My 82's switch is in the very back of the passenger head, and its a PITA to get to. I couldn't even find one so I took the power wire running to the switch, ran it back to the cab through a toggle, then back to the other prong on the plug to feed power to the solenoid. NOTE: the power will feed the solenoid for increased idle AND injection advance. (Should be the other green wire). The coolant temp sensor is supposed to shut off around 85 deg F, running that much additional advance with a fully warmed up engine is probably not a good idea. However, if you disconnect the green wire going to the injection pump and just leave the one on the solenoid, you have a handy high idle on command. If your injection advance is working you'll notice a definate change in the rattle when it is engaged.
  8. mstockton
    Apr 20, 2007
    99
    California
    You can also adjust the high idle solenoid by using a wrench on the hex end and turning it. Not sure which way is which though....
