i dont know what my d60 came out of!!!!!and i need calipers
Discussion in 'The Garage' started by ilikeitloud, Apr 4, 2004.
  1. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    so today i started swappin in the d60 everything bolted up perfect and i was sooooooo close to gettin done then i started workin on the brakes i went to go get new calipers and i have no clue what calipers i need from what year truck!!?! i believe its out of a chevy or dodge because the pumpkin is on the pass side. the are 2 piston calipers and LOOK kinda like a ford but i dont think the axle is out of a ford.all the chevy calipers we looked at were single piston and they didnt have any dodge ones avaiable for me to compare and none of the fords matched either. the BOM # is no where to be found even looked on the outer edge of the ring gear and found nothing. the guy told me that once i find out what the axle is out of come back. until then he cant help me.it is a low pinion D60 btw if that helps.
    thanx much matt
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    2 piston calipers are Ford calipers.
    Tell the parts guy you need GM calipers to fit any year between '77 to '86 K30/3500 or '87 to '91 V30/3500. /forums/images/graemlins/waytogo.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Bendix calipers mount the same whether they're on a dodge or chevy do they not?
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, they sure do. The only difference between the Dodge and GM D60 is the rotor thickness. All those other parts from the "C's" on outboard are the same. /forums/images/graemlins/waytogo.gif
  5. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Look at the spindle where the caliper brackets bolt on, if they are 5 bolt it is most definately a Ford otherwise Dodge or Chevy but AFAIK Ford is the only maker to use the twin piston caliper on a D60, it could also be a Ford D50.
  6. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I thought the Chevy and Dodge knuckles were different also because of Tie-rod taper and diameter. /forums/images/graemlins/thinking.gif
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    The housing can't be a Ford because he said the pumpkin is on the passenger side. /forums/images/graemlins/thinking.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    God only knows what outers it might have on it though.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    I've always thought it was the height of the tie-rod arm....one was higher than the other and the other lower. But most knuckles I've seen on eBay or aftermarket parts were quoted as Dodge and GM were interchangable.
    If someone has a Dodge knuckle laying around, get a part number posted up. The number is cast into the part. Get the number up and we can compare it to the GM knuckle. /forums/images/graemlins/thinking.gif
  10. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I never said anything about the housing. /forums/images/graemlins/ignore.gif
    Someone could have swapped the outers to a Ford. /forums/images/graemlins/thinking.gif
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Right. Take for example that Dan (KRAZIE87K5) has a Dodge housing with all Ford outer parts on his rig. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep, I know, I was at Dan's house last Thursday. /forums/images/graemlins/thumb.gif
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The chevy and dodge TRE's are the same taper. My dodge D60 is the same from knuckles out as my dad's GM D60.
  14. ilikeitloud
    Oct 30, 2003
    134
    im a newb so bare with me. i found some numbers stamped on the knuckle 620156L i dont know if those can mean anything??
    thanx for the help so far!
  15. ilikeitloud
    Oct 30, 2003
    134
    just went outside again the rotors are 1.25"thick and from what ive read on pirate only ford and dodge used 1.25" thick rotors.sooooooo i have twin piston calipers 1.25" rotors,5 bolt spindle mount pattern sooooooo im think i need calipers from a ford am i correct on assuming this?? if so what year/model ford should i ask for?
    thanx matt
  16. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Look for the BOM number again. This picture should help you find it.
  17. ilikeitloud
    Oct 30, 2003
    134
    yea i already checked there over and over and cant find anything.hellllllllllp me /forums/images/graemlins/frown.gif
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    thanx matt
    Tell them it's a '78 F350 or something.
  19. ilikeitloud
    Oct 30, 2003
    134
    or something /forums/images/graemlins/thinking.gif another observation that ive made is that the knuckle doesnt have clearance for large single-piston calipers like chevys do hmmmmm
  20. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    if you cant see the BOM number you have to use a wire brush to scrape down to it /forums/images/graemlins/thumb.gif
