I finally pick it up!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen91, Jan 13, 2001.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    The 14bff is the back of the truck. YEEEEEEHAAAAAAAAA!
    I can't wait till I do the lift so I can install that too.
    Can some one who has one please do me a favor? Can you measure from perch to perch and backing plate to backing plate. TIA
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    OK from the edge of one backing plate to the other is 53".
    Center to center of the perches looks like 42 1/2" but the tape is going across the rear cover so it is probably a little less than that. Congrats.
    Rene
  3. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Thanks Rene. Nice beaver!
    Not FROM the people
  4. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Now I'm alttle concerned. From backing to backing I have 51". From center of perch to center of perch is 40 1/2" or so. The over all from fub to fub, nut including the studs, is 67". If all I have to do is move the perch, then that's cool. Other wise I need to go talk to the guy I got it from. Using those measurements, do you know what this might be out of? Duelly? Post 87 Truck? Any help would be appreciated.
    Not FROM the people
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Sounds like it could be from a 1 ton. Mine has the same measurements and its from an 83 1 ton. It bolted up to my 71 but you will have to move the perches.</font color=blue>
  6. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    So is a sub 14ff the right length from perches?
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>If the sub was a 3/4 ton (they werent 1 ton, right?) it should bolt right up to your 88. </font color=blue>
  8. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You got the one ton version. You'll have to move the perches. However you do have the bigger brakes, 13" I believe.
    Rene
  9. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    So all I have to do is move the perches and the shock mounts? I can handle that. What are your measurements from outside to outside?
    Thanks all for your help.
    Not FROM the people
  10. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    OK one more trip to the carport and I have a dimension for you.
    Drumroll please............are ya on the edge of your seat yet?
    OK enough BS its 45" outside to outside.[​IMG]
    Rene
  11. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    My overall length is 671/2" from fom where the wheel sets on the hub to the other. Am I confusing you? Thanks again for your help.
    Or does someone know the overall length of a 10b or 12b from outer drum to outer drum.
    Not FROM the people
  12. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    No you're not confusing me, its just a horrendously difficult measurement to get with the wheels on and under the truck[​IMG]
    Your width should be very very close to a 10 or 12 bolt.
    Rene
  13. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    OK I found a spare rim and measured the distance from the mounting face to the back side of the rim. Then I measured between my rims on my truck. Mine is 67 1/2" drum face to drum face. 58" in between the rims plus the depth of the rim x2 (9 1/2" total). So it sounds like yours is the same width as mine.
    Rene
  14. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Ya I knew it would be difficult, so I hoping some one would have one on the ground to measure. But you answered my question and I greatlly appreciate all your help.
    Not FROM the people
  15. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    No problem, I remembered I had the spare rim after I posted[​IMG] That made it simple. Glad I could help.
    Rene
  16. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Blazen91, Measure your springs center to center. Then measure the pads on your 14bolt. I had to weld new pads on because my 14bolt was out of a USMC M1008. I was told that they had a wider frame then the K5. Let me know if that helped. Also check out your site your buddys K5 is sweet!. Oh yea like your window sticker.
