I finshed R&P Change!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83ZZ502_Jimmy, Jun 21, 2001.
  1. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I had to tell someone.!! I went from 3.42 to 4.10. What a difference with 35" tires. I have my truck back. Witht the ZZ4 it hauls major a$$ now. I also put a Moroso posi in the back too.
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '83 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD w/8.1L & Allison Auto
  2. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    how long did it take, what special tools were required, and congratulations, i hope i can learn to do that some day.
    sergio
  3. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    that sounds good to me. i put 35's on a little while ago, and i am ready for a gear swap. my mileage and performance have gone down since the new tires, so it's definitely time to save for the goodies.
    '89 chevrolet blazer / 1500 / K5 / tbi / 35's / black / power windows / scratched on the side
    '97 diamondback beach cruiser / 10spd on the grips / sparkly blue paint / cool white walls / beer holder on the front
    '01 razor scooter / light-up wheels / anodized fittings / raiders sticker
    <font color=purple>delta9blazer</font color=purple>
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Congrats Bro!! Feels good doesn it! I too did mine and went to 4.11 and running 33s right now and someday will step up to 35"SSRs..........
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  5. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    It took me about a day. Not counting part chasing. That took me another day. I took my time and checked everything twice.
    You need, (some things I had already):
    Magnetic Base, Dial Indicator, Shop Press (mine is 20 tons), bearing separtor, verneer (sp?) calipers, one mother of an impact gun (to crush the crush sleeve), Torque wrench, and some large (speciality impact sockets) I think I got it all
    Plus all of the bearings and R&P install kit.
    Also anything that one would need to remove the front brakes and associated parts.
    '94 Impala SS
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Just curios what kind of torque wench did you use ?
  7. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    I used a Sears 1/2" Drive. Click-type when you get to the preset torque.
    '94 Impala SS
  8. Executioner
    Feb 22, 2000
    1,530
    Is that what you used to check the pinion bearing pre-load ?
  9. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    No, I had an expert show me on one of my other trucks. He can do it by feel. He showed me what it is supposed to feel like. That one he put in has lasted 65,000 miles so far with my leadfoot.
    '94 Impala SS
  10. Executioner
    Feb 22, 2000
    1,530
    Ah, cool the Feel Method, it does work !
  11. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    yeah, I checked it with the marking compound, and it was perfect. Nothing like doing yourself...AND...having it work.
    '94 Impala SS
  12. Executioner
    Feb 22, 2000
    1,530
    "yeah, I checked it with the marking compound, and it was perfect."
    What is it ?
    You got me confused now !
  13. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    I crushed the crush sleeve with an impact gun until it "felt" right. I then put the assembled carrier into the housing. I shimmed until I got the proper backlash...(checked with a dial indicator), I then checked the wear pattern with the marking compound and it was in the correct pattern. I hope this clears up any confusion.
    '94 Impala SS
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wish someone would show me how to do it, that would be really cool. I need to learn. I'm sick of swapping the whole housing.
    I'm sure you know already, but make sure to break the gears in properly.
    Tim
