i found a nifty way to check for ground probs in the starting area
Discussion in 'The Garage' started by boggerless, Feb 22, 2006.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i had a bad ground and i took a set of jumper cables,hooked one to the neg on the battery and the other to the hood spring.then i hooked the other side of the cables to the one already on the neg side of the battery and that ones mate to the frame. and she turned over:D . so i disconnected the frame cables and she still turned over,so it was easy to know i had a bad body ground.i almost baught a new starter.:rolleyes:
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Ived had to do this a few times. the neg cable got torn up on somethin and i need to start the motor once i got it in. everybody was already closed so jumper cables to the rescue!:D
  3. boggerless
    May 26, 2003
    22,728
    96
    i wisn i would have thought of that before i got a new battery.:rolleyes: :haha:
