I found snow and broke my front end today
Discussion in 'The Garage' started by mountainexplorer, Feb 4, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    To retrieve one tire stranded up on the property in the middle of winter, I had to venture up my driveway which I may also add seemed to have more snow than any other area around here.
    Not that it was a whole lot of snow, but everywhere else we looked there was hardly any snow. 40% tread swampers and open diffs weren't the best combination for this type of snow. When we finally got about to where the tire was at, there was a loud SNAP and then clunk-clunk-clunk from the front end.
    The way it acted, it feels like I sheared a couple teeth off the ring gear, but I'm not sure what happened yet. Could have been from those few times I had to get big runs at the hills and the bumps were bad enough I had a front tire bounce up off the ground and land hard. It was rough enough the axles I had sitting on a pallet in the back cracked through the boards.
    Either way, after 2 hours and a broken front end, I now have my complete set of matched tires in one place.
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    What front axle did you bust? If its a 44 or 10b, I bet you sheared some ring gear teeth.
  3. mountainexplorer
    Nov 14, 2001
    4,903
    Dana 44 front swapped under it from a '77 truck. Last night I just put a new axle u-joint in it too and topped off the gear lube just to make sure it was ready for the task.
    Darn these non-Dana 60 axles. :mad:
  4. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    That sucks, pm me on the price for the spindles out:D
  5. mountainexplorer
    Nov 14, 2001
    4,903
    Haha, I can't part it out yet. Depending on what replacement I get for it, I may need these outers. When I first got this truck (the 1st time), these outers were on a flattop Dana 44 front that had 3.07 gears in it.
    Appearantly someone had blown the original 10-bolt, found a 1/2 ton 3.07 Dana 44 front and stuck the outers onto it without even thinking about gear ratios. So we got a 4.09 Dana 44 front from a '77 and put these outers and hubs on it and it's been this way for 2 years now.
    I have a lead on a 10-bolt 4.10 front minus outers, so if I get that I'll need these. If I don't get that I'll be robbing a rebuilt Dana 44 front I have from another project and swapping it under this '84. I already robbed the motor from that project for this truck... so may as well steal it all.
    All this parts swapping. Its a wonder I don't get sick and tired of it all.
  6. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Sounds like a parts run I went on last week, I went out to an old derilict wagoneer to pull a set of hubs to sell. Snow was over knee deep with no tire tracks all winter for the last 2 miles of the road/trail. Pulled the hubs off in the dark after shoveling the axle out, got them home and they where the wrong ones! Damn Napa parts books, o-well it was a good excuse to try out my "new" 38.5's.
