i found the vibration problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Kelboski, May 29, 2000.
  1. Kelboski
    Kelboski 1/2 ton status
    i got underneath my 84' last night to look it over after the lift was complete(which makes getting under very easy), and found that the u joint that connects to the front of the tranny has a little play in it from side to side. i'm going to have it replaced and hopefully the small vibration will go away. do you all think that is the problem most likely? the other u joints checked out just fine.
    oh, how far should the shaft be extended out from the t case with a 4' lift, i think its ok, but just checking.
    thanks in advance, Kelboski
