I got a deal on a new rearend! and front end.
Discussion in 'The Garage' started by Blue Goose, Aug 29, 2005.
  1. Blue Goose
    Blue Goose Registered Member
    Aug 22, 2005
    20
    South Dakota
    I was telling a guy I know about my 10 bolt blues, and the stupid 3.08 gears. He said he has a 10 bolt front axle, and a 12 bolt rearend. They already have 3.73 gears in them. He wants $100 bucks for both of them.
    sounds like a deal huh?
  2. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    if they are in good shape and u are just looking for lower gearing and no added strength, go for it. Its a lot cheaper than gettin them regeared...you might wanna make sure the bearings and all are good in them before u buy them...no need in gettin a "deal" then having to dump as much money into them as it would have been to just get someone to regear what u have.
  3. Blue Goose
    Aug 22, 2005
    20
    South Dakota
    also, if I go to buy this rearend. I'm gonna pop the covers off and take a look. What should I be looking for? I hope he didn't weld the spider gears or whatever it's called together so it's posi.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    If they are in a vehicle, then drive it and listen for noises.
    Otherwise, look for chunks floating about, broken or missing teeth on the ring and pinion/spiders. Look for rust - a little bit is probably OK, but a lot I would pass on. You will want the gear lube to look like gear lube, not a milkshake. Pass on the milkshake....
  5. d coenen
    d coenen Registered Member
    Jan 21, 2005
    76
    bonesteel s.d.
    where did you get such a deal im in s.d. to. anymore?
