I got a Fevah....and the only prescription is...............
Discussion in 'The Garage' started by uao85, Oct 8, 2006.
  1. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    going crew cab on my m1008..............I want to.........but Im poor.........but I found a cheap crew cab...........still poor..............need other parts that are a higher priority.................crew cabs are sweet.........still poor....no time...............damn I want to go crew cab!!!!!!!!!!!!!!!that is all. Darn you mtmike.........
    Remington
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    IIRC, I have ~$200 into my crew cab swap including the $75 I paid for the cab (not including fuel to get it to my friend's shop 100 miles away that had the proper tools or the $40 I sold the 2wd sector shaft for)
    But then again, it's kind of a hack job. Functional, but a hack job
    Food for thought :D
    And here's some motivational pictures:
  3. uao85
    Jan 2, 2004
    1,867
    Edge of insanity
    you did your swap on a short bed frame correct? how different do you think it would be with a lwb frame like my m1008 has??
    Remington
  4. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Yeah - I did mine on a shortbox frame..... I wouldn't even begin to speculate how much different it would be on a LWB frame because i've never torn one down. Depending on how long you're wanting your box to be, you may have to shorten the back of the frame which could make bumper mounting interesting.
    Here's some close-ups of underneath:
    Rear Passenger body mount
    Due to the clearance of the shock, the factory body mount would not work. The body puck is just sandwiched between the frame and the body with a bolt coming through. With a LWB frame this probably won't be an issue
    Middle body mount
    Rear angle (looking forward) on the middle body mount, showing again the body being notched for the frame.
    Middle body mount
    Front angle (looking back) notice the body is "notched" so the frame can run into it. This keeps the body level. The body mount puck is a standard (0 lift) puck.
    Front driver-side body mount
    This is a 3" body lift puck in the front
    Clearly the box is not "finished". The fuel tank is a 40 gallon suburban tank mounted high in the frame for axle clearance. Once complete I will use the remaining box floor to build a "shelf" above the tank so i can use more of my box.
  5. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    from the measurements I've made on my frame it should be easy it puts the rear cab mounts right on top of the spring crossmember which is the same height as the cab crossmember drill the holes and bolt on the cab .the hardest part would be shorteing the bed and relocating you fuel tanks
  6. uao85
    Jan 2, 2004
    1,867
    Edge of insanity
    crap I didnt even think about the fuel tanks since I have seen crew cab setups with the tanks tucked up under the sides................shat, back to square 1..................is there any difference between the fuel tanks from a crew cab and the fuel tanks from a LWB, I am converting to dual saddle tanks and already have the pass side tank..........DAMNNATION!!!
  7. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    No difference in the tanks, but the saddle-bag style won't work on a shortened crew. The tanks are designed to tuck under the rear seats, and unless you're at full wheelbase the tanks will obstruct the tires. Also, the tank won't work in the stock location due to the floor of the back seat cab area.
    This is why I put in the 40 gallon suburban tank.
  8. HoodRich
    HoodRich 1/2 ton status
    Jul 30, 2006
    160
    Kernersville, NC
    where you I see some more pics of Mike's rig, lots sweet.
  9. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Que?
  10. uao85
    Jan 2, 2004
    1,867
    Edge of insanity
    yeah about 5 minutes after I posted on the way to one of my classes I realized whole shortened bed thing hindering the tanks...........darn..............................well it looks like I will be having a pair of saddle tanks for sale sooner or later.
    Remington
  11. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Good luck with that... I have 3 of them that I can't even give away. I still have 1 (the other 2 were hauled to the scrap yard) if anyone wants to get it
  12. Tabb
    Tabb ROLL TIDE! AGAIN! GMOTM Winner
    May 2, 2006
    3,566
    21
    Heart of Dixie
    I gotta have more cowbell !
