i got a little problem with my steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by achuskies69, May 13, 2001.
  1. achuskies69
    achuskies69 1/2 ton status
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> ok when i would hit a bad bump in the road, my front end would start shaking back and forth and i would have to slow way down to around 20-25mph to get it to stop. I replaced both tie rod ends on my drag link and that helped a bunch but i still get the shaking when i hit a bad bump in the road every once in a while. WHat could this be? should i replace all my other tie rod ends ? I have a ORD Steering brace installed too, but it didnt stop this? any suggestions would be appeciated, thanks
    later got to roll.........
    <font color=green> 82 K5 - 350, 4" lift, 33's 3.08's
    soon to be rollin on dubs and some 35x15's
    and bumpin wit two 12" subs
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    check your steering damper.i broke mine and got all sorts of wobbles till i got it back on,on my old jeep cherokee.
    PURE INSANITY
    86 blazer see it at:<A target="_blank" HREF=http://www.zing.com/album/pictures.html?id=4292792569>http://www.zing.com/album/pictures.html?id=4292792569</A>
  3. achuskies69
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> well im running a rancho steering stabilizer, its a single unit, but ill check it. U think going to a dual stablilizer would be a good choice?
  4. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    possibly would help.have you checked the balljoints lately?do you have much play in the wheel,maybe the box is loose.and i dont know how to adjust it.so ill save you the question if it is loose.maybe someone else does.is the frame cracked at the box by chance?how bout the rod ends on the drag link?(box to wheel)
    PURE INSANITY
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    my 87 with 33" and 2" lift never did that. I didn't have a stabilizer at all. my 76 on 40's only had a single stabilizer. I would jack up the front and check everything out good. How are the shocks. I have seen on some lift kits with "loose springs" wobble when the shocks are shot. hows the front alignment? if the toe set is out, the tires will fight each other to pull straight after a bump.
    your right. I don't understand the jeep thing!
  6. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    I had a similar problem on a 2wd truck. It turned out to be a bad tire. Tread seperated!!
    The Few, The Proud, The K5 Blazer
  7. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    You shouldnt need to run more than one stabilizer. Have the tires balanced and check to see if all the suspension bolts are tight (except the spring eye bolts, they should just be snug). Have you removed the sway bar? If so, then you might want to consider reinstalling it and installing the ORD disconnect kit for when you are wheeling. The sway bar should help prevent the wobbles some. I had/have this problem too since i went to 35x15.50 swampers, but then I dont have the sway bar installed. Balancing the tires and installing a good, single stabilizer helped eliminate the problem for the most part. Stil get it once in a blue moon.
    '78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt rear w/ Detroit
    <A target="_blank" HREF=http://65.11.18.114>http://65.11.18.114</A>
  8. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
  9. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    check your bearings first to see if your safe to even be driving it after that check the ball joints and tires
    <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A> Not all Hispanics drive lowriders
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Check the balljoints and wheel bearings, tie rod ends. A steering stabilizer IMHOis a band aid to cover up front end problems. I had one on, then I replaced the tie rods and balljoints, never put it back on. Haven't had a problem in the 5 months since then.
    90K5
  11. Chaotical
    Chaotical Registered Member
    May 10, 2001
    29
    SLC, UT
    I had that problem too...
    It was after a long ass trip to Lake Havasu, AZ.. I drove for 13 Hrs... and when I got there it started wobbling bad when ever I hit a bump... I checked everything.. Ball joints, Dual Stabilizesr, Tie Rods everything.. .. it still did it..
    Then I was messing with with the wheel and I turned it and my stearing box started to move... It was as loose as a $2 whore... after I tightened it, it went away..
    Good thing it didn't come completly off.....
    Chaotic Entertainment
    Salt Lake City
