i got a question about an atv
Discussion in 'The Garage' started by 86chevybanshee, Aug 13, 2004.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    does anyone know how to do the timing on a honda 400ex?
  2. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    i know the banshee is a 2 stroke, and the 400ex is 4 stroke..but if its anything like a banshee, its all electronic (timing). Now if the carbs aren't synced then you just need to visualize the butterflies..open close, adjust, open close adjust...its not hard, just takes a lil time. hope it helps. call a local bike shop, they may advise you further.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ummm.... a banshee is 2 cyclinder 2 carb, the 400ex is 1 cylinder 1 carb, there is no syncing the carbs /forums/images/graemlins/screwy.gif /forums/images/graemlins/screwy.gif
    are you talking the cam timing or the ignition timing?
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    I believe he is talking about cam timing. Banshee's dont have a cam since they are 2 strokes. /forums/images/graemlins/wink.gif
  5. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    ya, unless u went in and messed with something...everything should be good to go. I dont even think 400ex have an adjustable stator like some bikes do...as for cam timing, there should be 2 holes on the left side cases pull the lil tabs that cover them and rotate yer engine till u see the marks in each hole...then yer dialed...if not then u need to pull the whole cover and get them lined up...least thats how u do it on my bike 300ex w/350X motor /forums/images/graemlins/thumb.gif
  6. exrider
    exrider Registered Member
    Jun 5, 2004
    30
    I just read through the top end rebuild of my Clymer Manual for my 400ex and it reads nothing about how to time the engine correctly. The only thing that it keeps covering is that there is a tick mark for top dead center on the cam and that needs to match up with another mark on the head I believe.
    What year do you have and any mods done?
  7. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    well my friend rebuilt his top end on it and need to know how to time it, but his is stock 2004, i used to own a 2002 400ex, had a 416 kit, hot cams cam, jetted, k&n, hmf pipe, and i think that all i can remember, i sold it and bought a 2004 banshee, all stock /forums/images/graemlins/peace.gif
  8. js4x4
    Jul 17, 2004
    798
    San Diego, CA
    I stand corrected big83...I'm a yamaha rider, so don't know any specs of a honda...wasn't sure if honda is a 2 cyl or not, just offered up some thoughts. Congrats on the Banshee! its the ONLY quad to ride IMO!! I had a 97' but the ex-wife got it in the D, so I got a YZ 250...shoulda fought to keep the Banshee /forums/images/graemlins/doah.gif
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its been a while since i worked on a 400ex, but it seems like most hondas have 2 small covers on the flywheel cover, they are slotted. remove both. rotate until you can see a mark in the top one, the cam gear will also have a mark. both marks go to the top. i don't remember how to make sure your on the correct side for ignition, but you have a 50:50 chance. if it backfires, remove the cam chain and rotate the crank 1 turn and she should start. /forums/images/graemlins/waytogo.gif
    BTW make sure to get the adjuster in correctly, my xr600 has a special tool so it adjusts right. the first time it jumped and the piston hit the intake valve, honda valve are EXPENCIVE, cost $50 each.
