i got a question on exhaust
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cootersk5, Aug 16, 2004.
  1. cootersk5
    cootersk5 Registered Member
    Aug 12, 2004
    48
    Frederick Maryland
    ok i want to run my own dual exhaust the drive side looks easy but on the pass. side do i go under or over the cross member and for four wheeling should i run it out in front of the rear tire or behind it /forums/images/graemlins/confused.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    go over the cross member, unless you wanna pick it up off the ground.
    ive seen a few both places, its easier to put it in front of the axle. if can still be ripped off in both places, depends on what you do. i have mine end about 2' infront of the axle straight back.
  3. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I want to do a dual exhaust on my rig one day, and I was thinking I might just have both my pipes routed down the left side of the transmission cross member, and have both exit on the left side in front of the rear tires. NASCAR routes their exhaust systems this way.
  4. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    hmm, never would have thought to do it that way.
  5. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    my duals run over the cross member and exit the sides right below the rear leaf hangers. Its a hooker kit from jegs for $130
  6. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    One reason I would not want an exhaust pipe to be routed on the right side of the transmission cross member and transfer case, on a GM 4X4, is because the exhaust pipe would be too close to the transfer case and heat it up, plus it would take some tight bends to route it around a transfer case.
  7. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    I would definitely say over the crossmember no matter what. And also, instead of in front of or behind the rear tire. Just keep it tucked up inbetween the frame rails and have it dump with a turn down in front of the rear axle on either side of the diff. I would say about 8 inches before the ubolts, and still tucked up high to be safe.
    Remington
