i got a tach
Discussion in 'The Garage' started by foolhardy, Jul 11, 2005.
  1. foolhardy
    foolhardy Registered Member
    Sep 16, 2004
    84
    yay i got a tach :D it is one ofthose ones that clamp around the spark plug wire
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    That is a Inductive-pickup type, i assume it has a switch to allow for 4,6 or 8 cyl. operation...?
  3. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    im confused- why would that matter? doesnt 1 rev = 1 rev :confused:
  4. foolhardy
    Sep 16, 2004
    84
    yes it does it was worth the 40.00 and it looks cool on my dash
  5. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Yes.......and no, a V-12 fires a plug every 30 degrees of crank rotation, V-10 every 36 degrees, V-8 every 45 degrees, V-6 every 60, I-4 every 90......
    so you need a compensation circuit for each motor arrangement
  6. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    if it is going off the sparkplug wire instead of coil- wouldnt it always be the same :confused: figure it would be same as a timing light in sorts always ticking same spot and counting tick give u RPM. sorry im little slow maybe and have never messed with a other then factory hookup tach- excuse my ignorance
  7. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    you're excused..... :wink1:
  8. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    still not understanding was the point :confused: now that i have stolen the thread
  9. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    it only fires one plug once per revolution, (unless youve got waste spark DIS)...... if you put it on the #1 plug..... every time it fires.... that's one rpm, regardless of engine setup (I4, V6, V8,V12, etc.)
    if the induction is on the coil wire, then yes, you need the compensation for engine setup because you are picking up spark for every plug, not just one.
  10. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    <whew> thats what i thought, originally it was said for spark wire, was getting worried - got the big 30 around the corner and senility knocking on my door :o :doah:
  11. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    I know what ur feeling bro........I'm pushing 50 n holding.... :haha:
  12. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Thank you for the correction, i confuse myself frequently.
    Taking into account the cam rotates at 2:1 with the crank or half-speed so the first revolution of the crank 1-8-4-3 second revolution fires 6-5-7-2
    I hope i got it right this time, it is difficult to place words outta what i'm thinking sometimes :bow:
