i got a tranny problem
Discussion in 'The Garage' started by big83chevy4x4, Jul 6, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    on my dads 94 4l60e, when it gets hot the tranny stays in 2nd gear. it starts in second and does not upshift or down shift. i get a code 72, which is "Vechicle Speed Sensor Loss". the code symtoms are "stays in second gear". i drove it to the dealer (about 15 miles) in the morning while it was cold and it didn't have a problem, bought a VSS from GM, drove back and put it in while it was hot. drove about 10 miles and it did it again.
    some history on this tranny, we bought it when it had 45,000 miles on it, fairly new. we rebuild the tranny at 304,000 miles, (it was still good, just the pump was cracked around the bushing and let the bushing spin and tore the seal out, so we desided to rebuild it) it now has 327,000 miles on it. all the electrical components were replaced at the time of rebuild, except the VSS.
    the only thing i can think of is the computer is bad /forums/images/graemlins/dunno.gif
    any ideas, im at a loss /forums/images/graemlins/thinking.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Obviously the ECM is not getting a pulse from the VSS. Check the wiring.
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the speedo still works, i thought the vss went to the ECM then the ECM sent the signal to the speedo. /forums/images/graemlins/thinking.gif
    ill check it anyway though
