I got me 396
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stomp, May 2, 2002.
  1. Stomp
    Stomp 1/2 ton status
    Feb 23, 2002
    168
    Hill Air Force Base Utah
    I got me a 396 bored .30 over!!! It's been tanked and the parts it need to be complete is a crank, pistons and cam. All he wants is the 350 thats in my truck now!! I'm so giddy!! Be looking for my 350 bare block thats in my garage on the market soon if anyone is looking for one.
    What all do I need to swap to convert to a BB. Headers I know but what about the motor mounts and my sm465???
  2. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    I do not know much about what parts you need to convert, maybe just new motor mouts for a BBC. However, be careful
    of early BBC, esp. 396's. They require a grooved rear cam journal so the mains get fed properly. I know about this cause we got a 396 from a person in turn key shape. We put it in a jetboat and it developed a knock soon after cause the mains were starved for oil. I pulled it apart and did some research and found the cam was not groved for that year. I cannot remeber the year of the block but I think it was a 65. Good luck. Hope this helps.
  3. Stomp
    Feb 23, 2002
    168
    I will keep that in mind! Thx for the info bud
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    the special cam is required for '65 & '66 year blocks only, '67 and later don't require anything special. your small block motor mounts and transmission mounting will all work. you will need all of the necessary accessory brackets and pulleys. nothing from the small block will fit. you can use the distributor out of the small block in the big block, and the flywheel and starter will fit up as well.
