I GOT THE BOAT!!!! - Need an answer on rear springs/suspension
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Mar 28, 2002.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    OK, I had the option of spending $3,000 on a D60 and other stuff or get a boat - since the K5 does not float that great I got the boat. The thing weighs about 5,000 lbs. and the question is:
    When towing a boat this size, what should I look for in rear springs? I am about to install my new 14 Bolt and I plan to install a Rough Country 4" lift kit. Will these springs and shocks be enough or should I start looking at helper springs or a air bags? Thanks.....
    Boat Link: <a target="_blank" href=http://www.geocities.com/keywestk5/Boat.html>http://www.geocities.com/keywestk5/Boat.html</a>
    Now I have two money pits ------
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
  3. I went with the same lift kit on my Suburban with the intent of towing. I think the Rough Country springs are a little stiffer than most, so I thought they would be better ideal. You still may need helper springs/air bags depending on how your Blazer squats. Also a weight distributing hitch may work better to help cut down on sway if you have any because of the short wheel base of Blazers.
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I use the stock springs with an 2" add-a-leaf and 4" blocks right now. No problems, but I dont like blocks for towing. That and my boat dosent weigh near as much as yours. Mine looks like this one: http://www.v-driveboat.com/rides.php?action=viewride&amp;id=19
    But mine has the headders sticking out like the top pic.
  5. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    If you don’t drive with the boat at the hook each day, you should pay attention to good handling without trailers. If the handling with trailer should be inakzeptabel, than go to install airlifts or hijakers.
    @ fireinthehole,
    The handling with trailer is about alike with the Blazer and Suburban. The Burb looses his advantage of the longer wheel base by its long overhang.
  6. Alex
    Alex Registered Member
    Jun 19, 2001
    78
    Northern California
  7. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Are you trying to get flexy with the K5 and use it for towing? I'm trying to get flexy with my Suburban and tow with it so I went with a 4" block and a 2.5" add a leaf. It's done well so far. I tow a lot of cars and trucks on a 25',2300lb car hauler.
    If you just want to tow I would go with heavy duty lift springs, a load leveling hitch, trailer brakes, and some sort of sway control. I used to do towing duties with my K5 but anything over 5000lbs would manhandle it. I also found that some 3/4 Trailering special Chevy's came with a rear sway bar. That could help too. The short wheelbase can make towing a real chore. Good luck.
    Here's a pic of the trailer behind my od K5.
    http://community.webshots.com/photo/27421333/27422983xHFqfdSagc
    Here's a pic of the Sub.
    http://community.webshots.com/photo/33766628/34331851UVsWpp
