I guess GM never stops changing things
Discussion in 'The Garage' started by cybrfire, Jan 23, 2004.
  1. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Pulled the drums off another 14BFF tonight and all was different than the last 5. This one had a spindle nut that was twice as thick as normal, a key stock peice in the key way and a retainer clip to hold the key stock in. Never seen that before. So I get the drum and brake parts off and went to put on the disc brake conversion. Won't go on, turns out there are crimp markings (something like that) on the spindle behind the machined area. Looked like a three jaw chuck had bit into the steel leaving burs behind. Once they were smoothed off the brake conversion went right on. Just when you think you've done something enough times you can do it in your sleep, GM throws a curve ball at you.
  2. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    We just bought a 87 crew cab that has the same set up your talking about, has 10 rear bolts though..........FF, Had a "lock ring" type thing holding a square key, and very thick nut. THis was the first one I'd ever done solo, all the one's I ever seen pop take apart had 2 nuts on each side.........
  3. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I think that is the standard, two nuts with a retainer in the middle. This one seemed different all the way along. Just little things, till I got inside the brake drums. This one also had the really big drums and all the ones I have apart before were the smaller size so maybe that is it. Kinda interesting though.
  4. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Yep my 14 bolt is like that.
  5. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    If the cover only had 10 bolts wouldn't that be a Dana rear end and not a Corp. 14?
    And wouldn't that explain some of the differences?
    All the Dana's I've worked on were different from the Corp. 14 axles.
  6. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Kert, I think the really large brake (13x3) drums, are off a truck with 8600 lb. or higher GVW.
  7. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    yea, i've seen that type of lock nut set-up on p-van axles
  8. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Should make a nice axle for my 4000 lbs. short box huh!!
  9. jwduke
    Aug 25, 2001
    721
    Thats no kidding!!! What ratio is it?
  10. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i have the keyway lock on one side and the two nuts on the other. one side came with only one adjusting nut /forums/images/graemlins/eek.gif so i stole the large adjusting nut/keyway lock from an old truck. . .paid the guy at the junkyard $20 for JUST it. . . and i mean GUY WHO WORKED at the junkyard, not the junkyard itself /forums/images/graemlins/rotfl.gif . . . now i'm kinda hoping if anyone buys that axle (which we put back together) they check it out before they use it /forums/images/graemlins/eek.gif
  11. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i think the keyway has JB7 brakes, and the two nuts have JB6
