I had a little OOPS this morning
Discussion in 'The Garage' started by mtnman210, Mar 30, 2006.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I forgot I had a battery in the back of the blazer when I drove it yesterday. I found it this morning and it had tipped over and leaked all over my back carpet. It put some nice big holes in the carpet and it still looks "wet"....is there any way to clean this up or should I just let it sit and dry out. And the carpet it already wrecked but now I'm concerned will the battery acid mess up the metal floor at all?
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Pull the carpet and hose the acid out out of the blazer. It will eat the paint. Also hose the carpet off real good and let it sit in the sun and dry.
  3. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    baking soda might help
  4. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Take out the carpet and rinse out the truck. Then pour a bunch of baking soda with some water or use apple cider vinegar where the acid spilled on the metal to neutralize some of it. Obviously battery acid is much stronger, but baking soda or apple cider vinegar will help. Then let it dry without wiping up the alkaline solution. Then wipe it up with alkaline again, let it sit then rinse off.
  5. goldwing2000
    goldwing2000 Guest
    +1
    I agree with skigirl except that you should mix the solution of baking soda and water and spray it all over everything before you rinse it, that way the acid is neutalized before you wash it over all the rest of your parts. After it neutralizes, then rinse it all out and scrub everything down with detergent and water.
    Then Rhino line your interior. :thumb:
  6. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    vinegar is not a good choice. vinegar is an acid like the battery. however, baking soda is a base, which has the opposite pH charge. a base is what you want if you are trying to neutralize. BTW, water has a "neutral" charge (which is about 7 on the pH scale).
  7. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    thanks for the help....I'm already going nuts right now. I'm suppose to be getting ready for my Accounting MidTerm (40% of my grade) that's at 3 today. I went to the truck to get a book and found my little surprise. Not exactly what I wanted to be doing before my test.
    carpet's pulled but the insolation is a pain to get up. I pulled the carpet and dumped a 2/3 full small box of baking soda on there. It's all that was in the house. I'll grab some more after my test tonight. Then I put some water soaked rags on it just because I don't have the time to pull it all right now. Now it's all done bubbling and drying in the sun with all the windows open. Hopefully I caught it in enough time. I really don't feel like doing any metal work on this truck right now.
    the hole in the carpet
    I'll give everything a good rinse tonight.
    Thanks for all the QUICK help:bow::bow::bow:
  8. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Get a couple of 2 liters of coke or pepsi and dump over everything. Being that it happened a while ago, I don't know if anything will help now.
  9. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    "neutral" meaning....water really doesn't do anything in way of getting rid of the acid??
  10. goldwing2000
    goldwing2000 Guest
    It will push it away but it doesn't 'deactivate' it. You have to put a base on an acid to neutralize it.
    Anyway, I wouldn't worry about the metal too much. It take long-term contact with battery acid to eat away metal with any major damage. At the very worst, you may have to repaint the bed but you won't have to replace any metal.
  11. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    actually it will, the battery acid (H204, sulfric acid) has a low acidic charge (probably somewhere around 2), water has a charge of 7, if you had equal emounts of both substances they would basically average to 4.5. water basically would dilute the acid, so it does help. however baking soda has a slightly basic charge of around 8.1, there for is better for neutralizing an acid. there are other bases that work better, but not as available and are more caustic and cause as much damage as the acid does.
    mythbusters disproved this, they basically dont do anything more than plain water.
  12. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    you might not wanna be barefoot when messing with battery acid, just a little warning as I see a foot in one of those pics.
  13. Skigirl
    Apr 2, 2001
    2,563
    Duh, masiony's right. Vinegar wrong. Baking soda right.
  14. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yep. Water will dilute, baking soda will neutralize. Coke and vinegar probably won't get you anywhere. And put some shoes on.:rolleyes:
  15. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    For a kick ass neutralizing use a drain cleaner Ph< 11! Lime would also work PH </=10
  16. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    you can, but that stuff is as bad as the battery acid. they are both far from 7 which is neutral, and therefor bad news if you get some on you.
  17. goldwing2000
    goldwing2000 Guest
    Worse, actually. Acid burns hurt while they're happening so you know what's going on.
    Base burns just rot your flesh away and it doen't hurt till it gets down to the bone. :eek1:
  18. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yeah, I'd definitely stick with the safe remedies. Can't really hurt yourself with one of the ingredients of your toothpaste (baking soda). I know I wouldn't brush my teeth with Drano...
  19. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    Whitener!...
    I wouldn't brush my teeth with Draino either!..bet that would whiten them up though...:wink1: ..
    You have to really look at the toothpaste tube first thing in the morning ,while your half asleep..
    DONT reach for the Preperation "H" tube by mistake!..:eek: :yikes: ...what fool decided to put it in a toothpaste looking tube anyway??:doah: ...
    I'd dump a few boxes of baking soda on the acid spill,and flush it with a garden hose thouroghly...I'd hate to see a floor looking just like the battery tray does...:eek1: ..I see it all too often here ,thanks to our DPW dumping tons of salt every time it snows here...:mad: ..
  20. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    Load it with baking soda, once the acid neutralizes itself with the baking soda, any extra baking soda will do no harm. Then flush the entire area thoroughly.
