i hate electrical!!
Discussion in 'The Garage' started by eightyone, May 17, 2004.
  1. eightyone
    eightyone 1/2 ton status
    Apr 25, 2004
    292
    long island
    so i got all my front lights and directionals hooked up to toggle switches...now its time for the back /forums/images/graemlins/yikes.gif i got the clip that comes fromt he rear lights to the firewall, there is 4 wires...on is for the reverse lights, one is for the left and its bright, one for the right that is bright, and one for both that is dim...i figure the brights are seperated for the directionals. so i hook the dim light wire tot he headlight switch, and run each bright one to the directionals...the problem is with the break lights. how do i get them to both light up at the same time, could i just use the wires that go tot he directionals and splice them inot the brake light switch?? /forums/images/graemlins/dunno.gif im sorry this is so long, but these rear lights are whats keeping me from getting this out of my shop, and onto the trails. thanks for any info. /forums/images/graemlins/thumb.gif
  2. Storm Trooper
    Nov 24, 2000
    4,640
    Normally the wires going back to the directional lights are also the same ones that work the brake lights. The inter connection of the two together is handled in the dash wiring. If you are doing some home made system you could just use a dual bulb setup to seperate them. I can't think of how they do it off hand so that both lights don't blink when you turn one side one right now. I suppose that it doesn't matter if the brake light wire connects to both right and left because the only time they would inter connect is when you stepped on the brake which wouldn't matter then anyway. I hope this makes some sence? /forums/images/graemlins/dunno.gif
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I still see those " hose-clamp-mount-to-the-column-old-fashioned-re-wired-blinker-kits " in JC Whitney catalogues. Probably easier than hitting a switch in a panic stop on the way to a trail ( if you are driving it to the trail on roads ) /forums/images/graemlins/k5.gif
  4. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    Get a haynes manual for 15 bucks. Or get someone to copy the wiring diagram for you and post it.
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I've got the wiring diagrams for a 78, might be the same. PM me if you need them. In mine, when you hit the brakes it actually sends power up into the steering column, and it goes through the whole turn signal assembly. Also, to my surprise, the front turn signals aren't connected to the rear signals in any way. I would try to keep the stock setup, if I were you. The turn signal/hazard/brake switching can get really messed up in the column, but you can get new ones at chevyduty.com pretty cheap. The wiring diagrams really help!
  6. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Also, if you splice both brake lights to the brake light switch, your turn signals will become hazard lights.
  7. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    You can do it with toggle switches using three relays. Two single pole relays will be controlled by the toggle switch for turn signals. The third relay will be a double pole relay and will be controlled by the brake switch. It will turn power on to control the other two relays. I don't have time right now, but could get you a diagram later.
