I hate my 16 gal. tank
Discussion in 'The Garage' started by 1987Chevy, Dec 28, 2005.
  1. 1987Chevy
    1987Chevy Registered Member
    Jun 29, 2005
    51
    Connecticut
    I have a short bed with a 16 gallon gas tank and just like the title says I hate it:mad: . the stupid thing goes through gas way to fast. I was wondering if a 20 gallon tank out of a long bed could fit in there with a little bit of tweaking and how hard it would be to install cause an extra 4 gallons would give me like an extra 50 miles to a tank and that would be nice:D. Any help would be greatly appreciated. thanks
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
  3. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    convert to dual 16s (one on each side) thats what i had in my shortbed
  4. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    I have the 31 gallon. You really should look for one if you are going to go to the trouble to do a swap. They usually came with a heavy duty skidplate and are pretty out of the way. You would have to be really trying hard to dent it. I have put some scratches in the skidplate and I only run 35s. The rear tank is also less trouble to hang. You would eliminate the need for the tank selection thing.
  5. dremu
    Feb 27, 2000
    15,957
    448
    East of San Francisco
    Amen! When I bought my crewcab, it had dual 20's ... but the switch between them was bad, and one wasn't even plumbed :(
    Your shortbed prolly gets better mileage than my sixpack, but I can't imagine having a 16 gallon tank ... it's bad enough with the 40 :)
    On a related topic, I've heared mention of kits to cross-fill, i.e. fill both tanks from one side. Anybody have any info on this?
    Alternately, can I make one tank feed into the other somehow? I think "gravity-fed" tanks are a no-no for CA emissions, which makes me want to do it all the more (truck is pre-smog, so they'll never see it :D ) I could even put a Blazer tank into the back under the bed, but I REALLY don't want to add ANOTHER tank switch setup... too complex, too much $$.
    -- A
  6. wildmouse216
    Dec 26, 2005
    135
    Rifle, Colorado
    You would think that you could replace the switch with just a T or Y hose fitting so that it feeds out of both tanks at once, but then you would have to pay attention to the fuel guage because there would be no backup tank.
  7. dremu
    Feb 27, 2000
    15,957
    448
    Well, the problem is that there are three lines to split, right ... fuel to the pump, a return line from the pump or carb or something, and a vent line, maybe? IIRC the switch I used had nine fittings, i.e. three in from each tank and three out to the fuel lines.
    -- A
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I only have 18 gallon tank(s).... one on each side.. it is nice but since it isnt a daily driver I only fill one.... to fill both is a pain as I have to pull up and fill one.. turn around and fill the other... :doah:
  9. 1987Chevy
    Jun 29, 2005
    51
    Connecticut
    I was thinking about those but I thought I would like the 20 gallon better because with the price of gas these days I would have to take out a small loan to fill a 31 gallon tank.:haha:
  10. gmtech954
    Dec 6, 2005
    96
    ct shoreline
    i had a bad switch on mine too so i just hooked up an electric pump off of one tank to a switch in the dash and used it as a transfer pump.
