I hate my car.
Discussion in 'The Garage' started by TSGB, Mar 8, 2005.
  1. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    Furd. Need I say more?
    1993 Cougar, 3.8L EFI. Auto 3 speed, with 4th overdrive.
    Well, it runs, but has less balls than a Catholic choir boy.
    It's always been sluggish, but there's been something causing it. It's always stuttered erratically since I got it about a year ago, and the stutter has followed me through an engine swap (exact same type of engine, only difference was miles and condition).
    I thought it was a vacuum leak, but my mechanic friends threw that out the window. So I changed the air and fuel filter, but it made no difference (even though I could barely blow through the fuel filter).
    So can someone make a diagnosis for me? Cheaper the better! If you need more information, just ask, and I shall answer.
    *sigh*. Hope I can get a 4runner soon.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    have you ever checked for trouble codes and done the KOEO and KOER tests?
    Also put a fuel pressure guage on it and see if it has fuel pump or regulator problems
  3. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    clogged cat
    transmission issues
    tv cable misadjusted
    egr system
    you can narrow it down by figuring out what parts were replaced
  4. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    My Blazer was really sluggish and I took it to a mech. friend of mine and he replaced the cat. What a difference that made.
  5. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    I'm having the auto class at school do an analysis on it (I'm not sure what all that entails), and it's supposed to take about 2 hours.
    So strip the cat, sprinkle some magic powder on the tranny, look up the tv cable (no idea what it is, where it is, what it does, or how cheap it is), and have Shucks run a test on it...
    Thanks!
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It's really hard to pin down the problem without a little more info, but most performance issues can be traced to the following:
    1. Weak spark, caused by bad wires, plugs or cap/rotor. Improperly adjusted spark plug gap. Improperly adjusted timing. Worn distributor. Stretched timing chain.
    2. Lack of fuel or low fuel pressure. Improper air/fuel mixture. Clogged air/fuel filters.
    3. Clogged or restricted exhaust system.
    Now, when you say your engine stutters, we need to know when exactly that occurs. Is the engine usually warm or cold? Is it hot or humid outside? DOes it happen off the line? Or perhaps at cruising speeds?
    Give us a wee bit more info and we may be able to help you solve this one, brother!!!
  7. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    it might be just 2 hours lab time
    hook it up to a 4 gas emissions analyzer before doing anything and write down the numbers.
    ask your teacher to show you how to use a vac gauge to determine for a clog converter. Also, how well the vacuum is on your motor.
    do a fuel pressure and flow test
    hook up a scan tool
    check your egr system
    The TV cable is just a cable that goes from the trans to the throttle body. It lets the trans know how open the throttle is open.
    Dont play with it and let your teacher just look at it. Because if it isn't adjusted correctly, it may fry your trans.
    Just like canmore said, we dont know much about your situation.
    Print out this page and bring it to class. Let your instructor test drive your car and he may have a better idea where to get started. If you have alldata, just print all the crap about your car.
  8. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    ---Now, when you say your engine stutters, we need to know when exactly that occurs. Is the engine usually warm or cold? Is it hot or humid outside? DOes it happen off the line? Or perhaps at cruising speeds?---
    Heh heh, I just tried to type out the sounds it makes, but that didn't go to well. It'll run, unless I push the pedal further, then it thumps, usually a lot of times quickly and erratically. Occasionally, if I'm really lucky, I get a good thud out of it. When I pump the gas moderately, about a third of the way down, and back up, over and over, I can get a below average acceleration out of it. When I floor it, and it downshifts, I accelerate extremely slowly, if I don't hold or lose speed. And, to top it off, I can barely get up the hill to my house now.
    This will happen at any time, warm, cold, hot, dry, humid, off the line, down the road, idling (not so bad, but it's there).
    I really appreciate the help guys! I hope I can make it to school tomorrow. It's a 20 mile interstate drive, but I think I'll take the backroads. Not much chance I'll get to speed.
  9. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Alright, my car is in the auto class right now. Told them to check the fuel pump, cat, and run codes on it. That's all I'll be able to do and get to work on time. Hopefully. I'll post up tonight with the results.
  10. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    Not sure how far you've checked into it, but i would also suspect the Mass-airflow sensor and possible a very dirty intake manifold and throttle body.
  11. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Gonna take a wild informed guess and say Mass Air flow Sensor (MAF).
  12. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    How would I go about cleaning the nooks and crannies on an intake manifold?
  13. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    "3m" makes a cleaning kit or you can go to a local garage you trust to do a cleaning.
