I HATE MY TRUCK!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigoltrux77, Aug 19, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    just when i thought i had the timing pretty close, and it was actually running ok with some good acceleration, IT GOES BACK! I was driving it today and i had to stop a little more sudden than usuall, then it started to idle like crap, and started to bckfire out of the carb a whole lot! Now when i accelerate, all i hear is POP POP POP POP!!! Someone please help me. What do i do?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    is the bolt holding the distibtor(sp?) tight? also check you vacume lines and make sure none are lose or leaking
  3. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I had that happening in my truck a while back, I fixed it by getting vortec heads and an HEI distributor.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    from pm </font><blockquote><font class="small">In reply to:</font><hr />
    yes the bolt is tight, and the vacuum lines are ok. What else could it be?
    ok how many miles are on the motor? when was the last tune up? have you checked the fireing order 5&amp;7 get crossed sometimes (guilty of this myself lol) what carb do you have?
  5. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    A bad cam lobe will do the exact same thing...progressively more backfiring as the lobe gets 'rounder' and 'rounder'.
    Rene
  6. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
    if it waas the cam, then why would it just all of a sudden do it when i hit the brakes? The engine has 35,000 miles on it. The carb is 650cfm edelbrock with edelbrock intake.
  7. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    If it was the cam it would do it all of the time. Double check all of your ignition components, check your spark plug gaps. Check the carbon button in the cap, check the ignition wires.
    What do you have the timing set at?
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it may sound stupid but take a good look at the plug wires it could be that one has been burnt by the exhaust manifolds i had the same thing it would run fine then i would hit a bump or something and then i would get a loud poping noise and i found out that i had a burnt wire and it would get close to the manifold and ark across and make it run like sh!t and do the poping thing /forums/images/icons/frown.gif
  9. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    Same here..I had a set of stock manifolds on my last blazer that would toast one of the leads and cause similar effects to whats been described. Just look for scorch marks around the exh manifold on 3/5 and 4/6 cylinders. I had to fab a small alloy shield to fix it, it turned out that a factory shield should have been in place.
  10. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    What's pretty close? Keep it right on the factory specs. Change the mechanical advance weights and vacuum advance and then you've got some room to mess with the settings. GOOOOOD tune-up is a must. Get a can of stuff called Top Engine Cleaner from your GM dealer, or a can of Sea-Foam. Get the engine warmed up and dump that stuff right down the primaries while running. All the directions are on the can. Do that and an oil change and that'll clean that sucker right up. Could be a sticking valve, and that may help. Firing order goes clockwise 1-8-4-3-6-5-7-2. Odd cylinders are on the driver's side and go 1-3-5-7 from front to back. Passenger side is the even deck with 2-4-6-8. Note where #1 is on the distributor before yanking wires.
  11. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    i made a very similar post about a month ago...set timing, shut off, timing goes out...
    turns out i got screwed over by a mechanic...he replaced a rear main seal for me cause i didnt have a good place to drop the tranny by myself...
    anyhow i brought it home and it leaked again right away...he swore his seal was fine, told me the next day the oil pump was bad....i called him on it and told him to keep his hands off of the engine, just replace the seal...(brand new engine...under 2k miles on it, oil pump steady at 65psi when driving)...
    anyhow he messed with the oil pump, didnt put it back in phase correctly, it was about 90 degrees off, then retarded the hell out of the distributor to get it to run...
    well it was actually still way off, i'd set the timing and it'd appear fine, but then it'd go out again...
    only way to fix it was crank the engine by hand to top dead center on #1, then with a long screwdriver turn the pump till i could get the rotor to hit #1 in the normal distributor position...
    then it was cake to fine tune it, and it hasnt lost a tune since then...
    but other causes of weird timing are worn cam like previously stated, vacuum leak with seriously mess with it, or a loose bolt on the distributor, but that wasnt the case on mine at all...
    but you might want to put the engine to tdc on #1 and check the rotor position, thats the sure fire way to get it set right...
  12. Grim-Reaper
    7,385
    Atlanta
    Pull the distributor. check the roll pin that hold the gear on the bottom.....maybe it's missing the pin/pin sheared and the gear is turning.
  13. downtime2nite
    downtime2nite Registered Member
    Jan 13, 2002
    20
    washington state
    check the carb. if you slammed on the brakes maybe the float jammed or sumpin!
  14. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Is the brake booster leaking all of the vacuum out?
  15. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i didnt read everyone elses post too carefully so i dunno if this has been said, Your Distributor could be a tooth off, or another thing to check would be take off the cap, take off the rotor, and look right under the rotor there are too Vacume advance weights they should not be over lapped at all anywhere, check those things as well if you havent all ready, the only reason i say this is cuz you basically desribed my problem and somone showed me this and it fixed it ;]] good luck and pls let me know what it was im always curious about that hehe
  16. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    umm, he he, if ya hate it give it to me...
    hehe ... i doubt you will
    give ya my buick for it?
    no, ok...
    hey man dont feel bad. i have not driven OR STARTED my blazer in 18 months... BLAH.. it fkn sucks.
    grant
  17. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
    I figured it out! There were tow rockers laying in the valve bay area..im suprised it even ran. I put em back on and adjusted all the valves then set the timing and it ran great!! Bad thing is i took the covers off again to check the valves adnd when i putem back on i brok one of the covers.Now im still truckless.!!!!!!!!
  18. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    but at least you found the problem /forums/images/icons/smile.gif
