I hate rivets
Discussion in 'The Garage' started by mightywhitey_k5, Feb 14, 2005.
  1. mightywhitey_k5
    mightywhitey_k5 Registered Member
    Sep 3, 2004
    74
    Dont get me wrong rivets are good for a lifetime of trouble free maintnence service; but when it comes time to remove them for the shackle flip kit, they SUCK! My advice dont drill. use an Ingersaulran air chisel and power through those bad boys :hack::woot: o ya where ear plugs dont be :screwy: , being inclosed where your gas tank used to be with that chisel running can make your ears ring for a few hours. When all that dam noise is said and done the flip kit is well worth it. Sorry for all the pisses and mones but i just felt like cursing those lit tle bastards. wish i would have picked up a pair of greasable bushings before i did this i didnt think about how cracked those things would be, now i have to do it later.
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    long barrel air hammers work best.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If I ever have another rig to the frame, I'm chiseling off every single rivet and replacing it with bolts and prevailing torque style lock nuts.
  4. mightywhitey_k5
    Sep 3, 2004
    74
    Ya i am shure those would work beater but i just used what was on hand at the time. good advice though.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    Tim, wanna borrow my air hammer? it works great for that! :D anybody wanna take any guesses how i know?
  6. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I hear you loud and clear. I thought I could do the shackle flip/ one ton swap in a day. Took a LONG part of that day just to get the rivits out, but I had to do the front hangar too. My Home Depot "Husky" air chisel wasn't quite up to the task on its own, so I centerpunched the rivets and drilled the centers with a 1/4" drill, the chisel took over after that,.
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I cut the tops off with an angle grinder. :grind: Getting them out was no problem after that. I used an air hammer with a pointed chisel and just knocked them out. Quick and easy.
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    If it's something easy to get to I take the torch and blow the heads off then beat them out with a punch and hammer. If it's not easy to get to without burning a hole somewhere I don't want to I use the angle grinder and a punch and hammer. If they don't come out after than then I drill them half way out with a 1/4" bit and beat them out with the punch and hammer.
    With the torch it takes a couple minutes to remove an entire bracket. With the angle grinder it usually takes an hour.
  9. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    i also used a 4" grinder to remove the heads then used a punch and a BFH:yikes: only i had to do both front/rear sets of hangers rear. the rear crossmember for rear hangers,the snubber brackets,front hangers both sets, i stopped counting at 80 :D harder than that was re-drilling every bracket and frame hole from the 3/8" to 1/2" just think of the rivets as your enemy!:saweet:
  10. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i think my next investment is an air hammer, iv got to many messed up thumbnails from missing the punch after i grind them out:mad:
  11. goldwing2000
    goldwing2000 Guest
    Flame Axe is ALWAYS the way to go. :weld:
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No, I have my own air hammer. When I moved my shackle mounts, I had all of those rivets out in a matter of minutes.
  13. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Nice to know Ill be doing the flip this weekend
  14. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Agreed. I installed a BDS shackle flip on my old '95 Dodge and ended up using an air chisel after getting frustrated with drilling and grinding.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My air hammer is a $49 CP long barrel, works very well.
  16. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Have you ever tried a unibit? I had to drill some holes in my frame to mount the crossmember for my divorced 205 and the unibit works great. I started by drilling a 1/8" pilot hole, then use the unibit to enlarge the holes to 1/2", it only takes about 20 seconds to enlarge the holes. When going from 3/8" to 1/2" a unibit works nice because as it enlarges the hole it stays centered so all your bolts will fit nice.
