I...hate...RIVETS
Discussion in 'The Garage' started by Jagged, Nov 13, 2005.
  1. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    So, I went to 76BlazerGuy's place to help him with his lift+shackle flip. All we had to get those rivets off was a grinder, a small (like 1/8") punch, a 2-lb hammer, and a big crowbar.
    Lots of cussing and beating the **** outta those brackets :grind: :hack: :angry1:
    Still have two stubborn rivets that won't let go of the bracket, but progress has been made. 76BlazerGuy's got a decent looking K5 now. 4" TC lift in the front, shackle flip rear, new shocks, and 33x12.50 Khumo MT's. Now he just needs to let me liven his engine up with a rebuild :deal:
  2. wafer brian
    wafer brian Newbie
    Feb 1, 2005
    canada
    rivets
    burn them with a welding machine crank her wide open watch out for your gas tank
  3. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Would have been nice... but we had a grinder, big hammer, small punch, and a crowbar to work with :(
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Rivets suck. An air hammer and an air grinder make them easier, but they suck either way.
  5. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    What about a cutting torch if you are swapping out the mounts?
  6. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Hey, this sounds familiar :haha:
    http://coloradok5.com/forums/showthread.php?t=155220
    Getting rid of those rivets makes it ALL soooo much easier for the future ... unbolting that flip to do 56"s will be sweet.
    Of course, undoing the rivets in the FRONT sucks... :doah:
    -- A
  7. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I didnt think my rivits were too bad.
    Grind the head off.
    Drill a hole through the rest of the rivit like a 1/8 or somthing.
    Then pound out the rivit with a sledge
    rince and repeat
  8. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Ehh, all the rivets are out... I was just whining about not having any good tools to really beat them out with.
    Like I said... we had a grinder, BFH, 1/8" punch, 1" chisel, and a BF Crowbar... no, these rivets don't punch out with a 1/8" punch. Had to grind the heads off, then use the BFH to whack the chisel between the bracket and frame to pop the bracket off the rivets. For the stubborn ones, it was a combination of the BF Crowbar and severe beating with the BFH.
  9. drofdar
    drofdar 1/2 ton status
    Dec 7, 2003
    113
    Fresno, CA
    When I did my fullsize flip, I just took the bed off first. Sounds like more work, but in the long run, the access I had made it soooo much easier! Gave me the opportunity to clean and paint the underside anyway.
  10. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    I plan on removing some rivits for some future projects on my truck, and I am going to use oxy/accetalyne with a cutting head torch to get the heads off, and then an air hammer to drive them the rest of the way out. This way I will not break a huge sweat trying to get those SOB's off.
  11. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    thats the ideal way but i don't hae the money for that sorta stuff rt now...
    first time i removed my rivits (for the shackle flip) i grinded them all the way down and beat them out...when i did it for the front hanger i grinded the head down some then chisled the rest off...i was tryin to keep the hanger in good shape and it worked for me. Having all those old rivits out is so nice tho, just unbolt the stuff if i ever need to move them (shouldn't after i get the 63" swap all done).
