I HATE these HEADERS!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddbogg89, Mar 18, 2003.
  1. muddbogg89
    muddbogg89 Registered Member
    Mar 19, 2002
    97
    Chicago(suburbs)
    When people talk about headers they never seen to mention what a pain in arse they are! /forums/images/graemlins/angryfire.gif I put some flow-tech headers on about 6 months ago and they are leaking from the collector and from the head. Got some allen head bolts and thought that would help,it did yery little. /forums/images/graemlins/confused.gif
    Not to mention that I've gotta do an oil filter relocation because of a 1/16in clearance.And it makes your spark plugs a lot harder to get to.
    And I dont notice much if any performance of milage increases (and I went to duals and no cats)
    I wish I would have stuck with the stock manifolds!
    O.K. all that being said,
    I do have a couple of questions,
    what kind of gaskets and collectors should I get, What are you guys running?
    I rememdered seeing something in that show Trucks! about some collectors that were good for not leaking anyone remember that?
    /forums/images/graemlins/k5.gif
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I am using Earl's Aluminum gaskets on my new engine, I have not fired it yet but they seem like a good gasket
    the insert that can be replaced seems to be a soft material that would from to the header flange and the head,
    it is the same at the collector
  3. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Welcome to the wonderfull world of headers!
    For the head gaskets I have had Excellent results with the Copper gaskets by Mr. Gasket. I have these on two vehicles and Love them. On my 91 I used the Stage 8 Locking bolts and haven't had a problem with them.
    For Collectors I'm now using Mr. Gasket Ultraseal gaskets and Header Hush. I fought many rounds with the Aluminum gaskets and they have worked well on my passenger side but I never could get the drivers to seal, and It's the important one being the 02 sensor is on that side. I'm still running them on the passenger side w/ no problems.
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I hate headers on SBCs other engines that don't have that combined middle set of ports seem to work better. Well I'm glad I don't have any thing with a mouse motor anymore.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    A trick that works for me is to cut the flange between the front cyl and the middle cyl's and the back cyl. It lets everything seal better. I like copper gaskets at the flange, and a doanut style gasket at the collector.
  6. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    I have a set of Doug Thorley Tri-Y coated headers and have not had one problem in the last 16,000 miles that I've used them. I used a Mr. Gasket header gasket, and regular header bolts. I did have to change to header style spark plugs. I have read posts here in the past, about it being very important to tighten the header bolts often when you first install them. After the engine has been run and cooled off, tighten up the header bolts, and go through this hot/cool cycle a number of times to make sure that the bolts are tight. I did that and it has worked for me. Other than that, very easy installation and definite seat of the pants increase in power.
  7. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    If you want your headers to stop leaking at the collectors do like I did and replace the flat, 3-bolt ones with flowmaster ball flange collectors. You have to cut the old stuff off your headers and exhaust pipes and weld on the new parts but the results are amazing, you wont have any more problems. I did a little write up on them on my page, http://pages.sbcglobal.net/xnoahx/
  8. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Right there is your problem. Flow-Tech headers leak like a sieve. Buy some Hooker or Doug Thorley headers and I bet your problem goes away. You get what you pay for in the world of headers; cheap headers are cheap for a reason.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I *hate* headers too. The only headers I would run are the Thorley Tri-Y truck headers. They have exactly the characteristics needed by our trucks, and they don't have many of the problems other headers do due to heavy high quality construction. But, they are $$$... Other than that, some slight mods will let you run rams-horn manifolds which also work well and don’t generally leak…
  10. BowtieGuy3
    BowtieGuy3 Guest
    I use a little trick that I picked up from racing...It requires some machining, but works out really well. I grab a machinist's straight edge, and pretty much machine the flange until it's trued up, then (as stated in another reply) trim the flange so each set of ports is its own individual flange. It also seems to be easier to install since the 3 sections of the header flange have a wee bit more flexability then the one somplete flange. By doing all of that, and using the copper gaskets, I havent had a exh. gasket blow out in quite sometime, on the truck, or the racecar (that has 1-piece, over-the-top headers, Imagine that hell..lol).
  11. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    i also have the flow-tech headers
    the guy at muffler brothers,
    said with cheap headers to weld the flanges up, so i had him weld the flanges,
    the only problen i have is the bolts work loose that hold em to the manifold,
    any idea's how to stop em from coming loose?
  12. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    They were called "the header hush", but i did a search online and didnt find anything on em
  13. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Run em upside down out yer hood. You'll never hear your exhaust leaking again.
  14. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    I have flowtech's and they SUCK would never BUY them again !
    I also use the stage 8 bolts which are a good design but suck none the less and percy's Aluminum Gaskets . Either Earl's or Percy's are the best gaskets you can get . A little expensive but good gaskets . So good luck
  15. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Does that really work???
    I'll have to try it!
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  16. BowtieGuy3
    BowtieGuy3 Guest
    I got 2 ideas how to keep those puppies from working loose....Red Loctite or Safety Wire. The Safety Wire thing works great, but its a lil' time consuming, but works like a charm. I recommend it for every bolt that could possibly work itself loose... /forums/images/graemlins/thumb.gif
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    In that case my rig would look like one big twisty-tie. /forums/images/graemlins/thumb.gif
    Another thing that occurs to me is an old drag racing trick some of my friends used years ago to help with leaky header problems. Take a thick fiber gasket (some even used 2! per side) and soak them in water before bolting them down. Let dry, then heat 'er up. Apparently it allows the fiber gaskets to flow around the deformity due to welds or whatever and the leaks are gone. <shrug> YMMV...
  18. dyeager535
    26,977
    Are you saying that you basically cut down the welds on the head side of the flange?
    I've always wondered why (at least on the headers I have seen) that the welds that hold the tubes to the head flange are on the mating surface. Seems like a real dumb idea to me. According to someone else I talked to, the welded section is *supposed* to fit inside the manifold gasket hole, but I've not used a set of headers yet.
    Is that a problem, or do most of the welds actually fit inside the gasket cutout? Seems to me that welding on the outside of the flange would be the "right" way to do it, even if more time consuming/expensive.
  19. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    that's true, i guaranten you'd never HEAR them leaking/forums/images/graemlins/grin.gif/forums/images/graemlins/grin.gif
  20. caryhenry
    caryhenry Registered Member
    Sep 28, 2002
    78
    Tallahassee, Fl
    you may also want to use permatex's copper-seal. I used this on my silverado cause I kept blowing out the rear port seal. It works just like rtv sealant but is high temp and oxygen sensor safe.
