I hate to ask stupid questions, but....
Discussion in '1982-Present GM Diesel' started by chevblazk5, Aug 3, 2004.
  1. chevblazk5
    chevblazk5 1/2 ton status Premium Member
    Mar 19, 2002
    257
    Sayreville, NJ
    I just got an '85 C30 with 6.2 diesel. The motor is out of a different truck and only god knows how many miles are on this thing. The truck starts up easily with very little black smoke. I want to pull the 6.2 out for my '90 Suburban and here's what I want to know:
    What should I do to the motor before I do the swap? I was planning on changing the head gasket, swap the timing chain for gears and I already have new glow plugs from Kennedy diesel. Is there anything else that I should do? I do have a new banks turbo kit, but that's gonna have to wait as I'd like to take care of the rust before it's too late.
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I would first compression test it. Then pull your injectors and have them tested, some shops will do it for free.
    I would replace the vibration dampner, rear main seal, front timing cover/crank seal, oil pan gasket, valve cover gaskets, put a new high flow water pump on it from penisular diesel and I would also go with the dual thermostat crossover.
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    What does the dual-stat crossover do for the motor?
  4. azblazor
    May 5, 2001
    1,953
    It flows a lot more coolant. It is a factory upgrade in 97 that can be retrofitted back to the 6.2's. You just need to cut and rotate the outlet (t-stat cover) and reweld it and notch out the throttle bracket.
  5. chevblazk5
    Mar 19, 2002
    257
    Sayreville, NJ
    That's the first thing I'm doing this Sunday and I'll go from there. I just found out that the motor has almost115,000 miles.
