I have 2 Major problems need help quick
Discussion in 'The Garage' started by dheavychevy38, Feb 19, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    I have a 89 k5 with a 350 I bought it with the fuel tank out cause the pump was bad so a new pump staps and a sending unit later the darn thing still doesn't work any help would be great???????????????????????/
    The other thing is the floor 8 inchs behind the rear seat to the tailgate and the rear beam is rotten to the bone i can see the ground any ideas where to get parts or fabricate i'm am pretty well skilled at mechanics and a fabricator cause thats my job . /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  2. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Help me I'm going to get a concrete saw and start chopping please help
  3. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Are you getting any fuel to the fuel filter? Any coming out of the filter? Is the fuel pump relay on the firewall picking up. Can you hear the pump run for a few seconds after turning on the ignition switch?
  4. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    The pump is not running i know i have a good ground.
    Not sure if the relay is working or getting power don't have poper tools at house do you know the wiring diagram for the relay??????
    How about the rotten floor any ideas i will post pics when i figure out how
  5. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
  6. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    You did check the fuse, right?
  7. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    jcwhitney sells replacement bed panels for the are you are mentioning. His problem isn't just the hinge area like it was with mine(I just put a piece of angle iron on and welded it fast) his whole bed sounds bad.
  9. Kyle89K5
    2,273
    OKLAHOMA
    No, but the sheetmetal that makes up the floorboard is cake, the support is tricky...
  10. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    I'm not sure on the fuse they all look good but the marking are rubbed off the fuse block.
    What do you think of cutting the bed out of a pickup and welding it in place or get some tubeing for the rear hinge area and put some diamond plate or flat steel /forums/images/graemlins/k5.gif
    Stupid .q's how to post pics
  11. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    the whole bed from the rear seat to the gate and support is bad
    How do you post pics and i'll show how bad it is /forums/images/graemlins/k5.gif
