I Have A Odd Question About The Strength Of The Stock Bumpers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Dec 31, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I want to cut square holes on both sides of the bumpers(one on the right and one on the left) for a Hi-Lift Jack to be safetly inserted and not slip off. I will make the holes close to the braces. My question is will the bumper/braces hold up or will it just bend? I want a safe place to use a Hi-Lift but I dont have a flat surface to use it at.
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    If you weld, maybe you could weld a piece of angle iron a few inches long above each hole for extra support.
    My rear bumper was only slightly bent after I backed into a co-worker's Bronco II--her drivers door was mangled!!
    [​IMG] Semper Maintenance!
  3. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    why not fabricate brackets and use the bumper bolts to go through the brackets.
    Knife.
    knife.coloradok5.com
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Why don't you use the HiLift attachment for the curved bumpers? Hopefully it works since I just bought one yesterday for my jack. Looks like it will solve the problem of slippage. Part #BL-250.
    Smitty
  5. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    Use the attachment offered by Hi-Lift. I have one with the attachment and it works fine.
    <A target="_blank" HREF=http://k5junkie.coloradok5.com/>http://k5junkie.coloradok5.com/</A>
  6. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    It says that the hook attachment is only rated for 3000lbs so I figured that is a weak link, plus I like overkill[​IMG]
    <blockquote><font size=1>In reply to:</font><hr>
    The Bumper Lift is designed to fit most slotted or curved bumpers, for quick and easy lifting. Bumper Lift has a 3,000 lb. capacity (1361 kg).
    When used with the Hi-Lift Jack, which is not itself designed to be used on curved or tubular bumpers, the Bumper Lift makes raising one wheel of most average sized vehicles up to 2" (5 cm) above the ground an easy task. Never attempt to lift more than one wheel at a time.
    <hr></blockquote>
    What does it mean, when it says it makes lifting vehicles up to 2" off the ground a easy task? Does that mean it can only safetly lift the truck up 2"?
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Looks like a litle C Y A on the part of Hi-Lift. Maybe they're worried that their name suggests you should lift your vehicles tire 'high' off the ground. A hi-lift will easily lift one corner of a vehicle as high as you want, however the higher you go the more unstable it becomes, which is probably why they are saying 2".
    On my Jimmy I have to chain the axle if I want the tire off the ground with my 48". Sometimes flexy can bite you on your a$$ [​IMG]
    As far as those curved bumper attachments, 3000 lbs is overkill. Even if your truck weighs 6000 lbs you're only lifting one corner at a time. That would only be 1500 lbs or so.
    Rene
  8. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Have to agree with the CYA on the lift. The jack instructions say not to lift the tire more than 2". Doesn't matter if you're using the attachment or not.
    Smitty
  9. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Got a flat out wheelin once... on a hill... Had to put a big rock under the 48" jack, just to get "hi" enough. Very scary- not the safest thing I've ever done[​IMG]
  10. 88MudBeast
    88MudBeast Registered Member
    Nov 8, 2000
    67
    Dallas, TX
    Yeah, my bumper was fine after i riped off the bumper of an illegally parked 4 runner. Sure my bumper was fine, but somehow i ended up having to pay $375 for an accident that wasnt my fault.
    Big Jake
    Its gonna be a WILD ride!
