I have a problem Need Help!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by blazerboy72, Apr 11, 2002.
  1. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    I just took my top off for the first time since i had the floors and body bushings replaced, Now my doors want open or close. Could i put a smittybuilt cage in it a nd weld a bar to the windshield to help that out please help!!! thank you
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You should have changed the bushings w/ the top on. It would have helped keep everything lined up. Did you replace all the stock body mount shims in the right spot? You will need to shim the body till it is straight.
  3. blazerboy72
    Mar 29, 2002
    260
    hiram ga
    I did but when i took the top off about a month later one door won't close and the other won't open
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Time to shim it then. Loosen up all the body mount bolts and add shims (most likely under the doors and to the rear) till the doors both open and close. Then tighten up the bolts.
    I need to do this to my truck sometime...
  5. kilomanjaro
    kilomanjaro 1/2 ton status
    Feb 22, 2000
    229
    Manhattan, Ks USA
    are your rocker boxes rusted out? if they are, that causes the windshield frame to lean back and makes the doors stick.
  6. blazerboy72
    Mar 29, 2002
    260
    hiram ga
    they aren't too bad there is a little rust on one
