I have a strange NP 208
Discussion in 'The Garage' started by adamforsythe, Apr 11, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Ever since last night my Np208 has been kicking into 4 wheel on its own. What would be causing this? I know my linkage is screwed up becuase it kicks out of 4 low on it's own
    Adam
  2. rlhenry
    rlhenry Registered Member
    Mar 6, 2002
    93
    Morenci, AZ
    Mine will kick out of 4L as well. I think under body flex the sheetmetal may be coming in contact with the shifter and kicking it out. I've lowered the transfer case and I think the rear-ward tilt has moved the shifter too close to the sheetmetal. I think I just need to get in there and do some trimming. As far as your problem, I haven't heard of one kicking into 4wd out of 2H. That's a new one on me.
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Well, improper linkage adjustment can cause just about any problem with shifting. You want to make sure it sits in its designated positions firmly. I would adjust it so you feel the case go into its designated positions well, and stays there.
    Else, I might look at you shift fork pads. They might allow too much movement and allow the synchros to engage and drag the rest until its into gear.
    If your gonna keep that case, might want to plan on a rebuild, cause your probably gonna want to tear into it anyway.
    Or you can get one thats already rebuilt:whistle::whistle:
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Another reason for a T-case to kick out is a worn CV in the front shaft. My 77 w/ a 203 started doing that and I didn't know why. Linkage was all good. then shortly after the slop in my CV got bad enough I could feel the vibe, and the kicking out got worse.. after I rebuilt it, it was gone.
  5. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    Mine used to kick out of 4 hi. It was because the saggy mounts screwed up the linkage. after new mounts it works fine.
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Mine kicks out of 4H all the time.
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    487
    Grand Rapids area
    It's trying to tell you something. It wants to go wheeling.
  8. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    Bad motor mounts will cause them to go into 4 wheel drive on there own. Also check the tranny mount.
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i had one that was stuck in 4wd, but i still had nuetral and 4 low, just no 2 low. i took the tail housing off and the rear output bearing fell out, i pressed it back in and i had 2wd again.
    never heard of one poping into 4hi though. bad motor mounts could cause it
  10. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    hmmm..
    The NP208 in my 82 K20 refuses to go into 2hi--or should I say its IN 2hi,but the front wheels are still getting power applied!..(no difference between 2hi and 4hi..):confused:
    I've had it 2 years now this way,I just unlock the hubs and let everything up front spin,but I'm concerned someday whatever is causing this will fubar the T-case...I've adjusted the linkage to no avail...all the other positions work normally,4lo,4hi,neutral,etc..I assume its internal,something is not disengaging,etc..
    I have a spare T-case waiting in case this one decides to grenade..:crazy:
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    thats EXACTLY what mine did and the bearing was out of the tail housing, im guessing putting pressure on the mode selector keeping it in 4wd. i pressed the bearing back into the tailhousing and i had 2wd again.
    i like how dodge put a snapring on that bearing to keep it in place.
  12. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Are you sure it is kicking into 4wd? Does the 4x4 light just come on or you actually are going into 4 wheel? Most likely if you are in 2wd then it would pop into nutral first.
