I have an odd question
Discussion in 'The Garage' started by big jimmy 91, Aug 9, 2004.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I have a 91 Jimmy 350 , 700R, NP 241
    It has 2 HI , 4HI , N , 4LOW shift on the transfer case
    My question is , can I put it into 4 LOW without the hubs locked to have a 2 LOW and not do any damage to anything
    I would like to do this if it can be done without causing damage to anything in the drive train
    So any reason why this can't be done ?
    /forums/images/graemlins/ears.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    can be, will cause internal wear on the gears and bearings on the fornt cause they will be spinning. But thats no more than if the hubs were locked. Front shaft will also be spinning. Basically there isn't much of a reason to do it. Not that I can think of anyway, 4 wheel can only help /forums/images/graemlins/smile.gif
  3. big jimmy 91
    Feb 21, 2004
    639
    I have 2 reasons to do it
    1. I need a really low gear to pull heavy equipment at a farm at a very slow speed
    2. I would like to pull into the burnout box at the drag races and light up the 35 X 14's just to see the reaction it would get /forums/images/graemlins/eek.gif
  4. jrsheets
    jrsheets Registered Member
    Mar 15, 2004
    68
    Katy, Texas
    just make sure your drivetrain is strong enough for it.
  5. big jimmy 91
    Feb 21, 2004
    639
    It's stock /forums/images/graemlins/blush.gif
    But I have no better excuse to upgrade it than a mechanical failure /forums/images/graemlins/whistling.gif
  6. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    I'd be careful if you use low range with the hubs unlocked--I did that to show off in my 72 K5 I had years ago--I stripped the U-joint flange splines right out on the rear end(it was a 12 bolt too!)--didnt impress anyone,in fact--I still get ribbed about that night by my friends,How I had to drive home in 4wd for 20 miles on back roads at 20mph! /forums/images/graemlins/blush.gif. Its possible to snap axle shafts and spider gears with the tremendous rourque available in low range,even with a wimpy motor,so be expecting something to break,espescially if its half ton rear ends!. /forums/images/graemlins/eek.gif
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Well for the farm stuff, why not just use 4wd?
    And for the burnouts.... Do you have lock outs or auto hubs??? And as long as you break the tires loose, you should be ok. Just dont rev too high since 4low will get the rpms up quicker!
  8. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I would have to second this, be very careful, you could grenade a lot of stuff very quickly, just trying to show off.
  9. big jimmy 91
    Feb 21, 2004
    639
    For the farm stuff I have to pull hay wagons and such for up to 15 miles down the highway shoulder very slow , 10MPH.
    I have man. hubs , 10bolts , with a gov bomb in the rear /forums/images/graemlins/blush.gif
    BTW , I have destroyed 2 diffs. in a mustang and 1 1/2 ton diff in my 85 chev /forums/images/graemlins/yikes.gif
    Thanks for everyones input , I will take it all into consideration /forums/images/graemlins/waytogo.gif
  10. fwdjunky
    fwdjunky 1/2 ton status
    Oct 12, 2003
    499
    Maricopa, AZ
    A little late, but just food for thought, the 2wd LO thing is one of my favorite tricks for backing up large trailers in tight spaces...just gives you more control.
