i have few tranny problems please help i am new to the mechanical world
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tmaxxer9, Feb 12, 2003.
  1. tmaxxer9
    tmaxxer9 1/2 ton status
    Feb 12, 2003
    195
    Minnesota
    /forums/images/graemlins/1zhelp.gifOk I am new to vehicles and there power plants. Well this really has nothing to do with the engine, but instead the tranny. Ok sometimes when i drive it I can not go backwards when in the R postion. Instead it will go forward same with it being in the N postion. What do you think the problem could be. I think I either have a big air bubble in the tranny or I need to get it rebuilt. It is a 75 K5 blazer with a 350 in it. So any help would be great.
  2. VitaminK5
    VitaminK5 Registered Member
    Feb 11, 2003
    6
    NJTPK Exit 11, NJ
    Drop the pan and make sure of where the linkage is connecting. There is a slotted arm for opening fluid ports that let you get in gear. Sticking valve body...small plunger..big spring! Clean fluid or metal shavings? Loose linkage, maybe. Gear selector arm under chassis where it pivots.
  3. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Whoa, take it easy, before you drop the pan make sure the linkage is adjusted right!!!! Sounds like the problem to me. - doug
  4. mudober
    mudober Registered Member
    Feb 19, 2002
    23
    You may want to take it to your local tranny shop if the pan has to come off.It wont cost you much if you bring your own fluid to refill it to have it adj.Tranny stuff can be confusing looking up at it from the ground.Not to mention they drip all over you.
  5. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    See I would take it to a shop, but how am i suppos to learn anything if I have other people do all my dirty work. See I ain't affraid of a little fluid dripping on me. So if anyone has any other ideas please help. But those of you who threw in your 2 cents thank you very much.
  6. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    Ok i crawled under the truck and had a friend move the shifter as i watched the linkage and it seemed to move fine, so what else could be wrong?? /forums/images/graemlins/confused.gif
  7. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Did you check the little plastic bushing that sits in that little metal cup where the shifter pivots... I don't know how to explain it exactly, but you should know what I'm talking about if you were under there. Its where the up and down movement of the linkage pivots and changes directions to allow it to rotate and shift the gears... if that little plastic bushing is gone or badly worn you can have problems with it going in and out of gear. Also, inside of the pan the detent has a little stamped out piece of metal with a roller on the end that holds the selecter in place... its actually what makes the clicking noise when you shift it. The metal can get weak and not hold it in gear as well as it should. If you can come across another one of those pieces and cut the roller off of one and install the two of them into the tranny, that can help hold it in gear better.
    Hopefully you can make heads or tails out of what I've written... talking about things that have to do with a tranny is hard......... doing it in person is easier. Also, dont be afraid of your tranny, there not THAT bad... and if you have any more questions you can PM me and I can help out more... I've rebuilt a couple of TH350s and 1 Th400.
  8. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    A simple experiment..
    When it doesn't go backwards...take the shifter, lift it out of the detent...and move it up toward Park, and down toward Drive...
    If it suddenly goes into gear..the problem most likely is the linkage..
    It could be simple adjustment...slightly complicated, but not too much..
    Before you attempt adjustment, you have to check for loosness in the shifter mech..
    Besides the wear and tear on the linkage itself...
    The linkage is dependent on the distance from the cab to the frame/engine...
    Sagging body mounts cause the most change in linkage adjustment
    Motor mounts, because of the "eqalizer shaft" between the frame and engine, not as much
    As was pointed out, there is a plastic bushing on the frame side of the equalizer arm, but more important, at the bottom of the steering coulum, where the shift lever sticks out, and the linkage connects, there is a rubber bushing that sometimes goes bad...
    Have someone moves the shifter for you , and if you see play at that point...replace the bushing and try it again
    Also, if someone moves the shift lever, and the external shift lever doesn't move as much, the problem is in the column
    The shift lever/collar, at below the steering wheel, can wear out inside, or the pin in the shift lever gets loose...
    If all externals are tight, little lost motion,...AND THE CAR GOES INTO GEAR when you move the shifter...
    Try adjusting it first..
    IF still no luck, and the THE TRANS GOES INTO GEAR WHEN YOU JIGGLE THE LEVER..
    The shift rod goes through the trans case into the pan area, and has a cam/lever aragnement bolted on the other end..it is possible for the nut to come loose..
    you will need to pull the pan
    IF YOU CANNOT GET THE TRANS TO GO INTO GEAR, by moving the lever back and forth, you are probably loosing the Lo/Reverse or Direct clutch in the trans, and it will need to be dissassembled
    Hope this helps.. /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
