I have my steering box off...
Discussion in 'The Garage' started by k5freak44, Sep 16, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Hey guys, i just took off my steering box and i have some questions.
    What is the best way to find cracks?
    I only have one crack for sure, but there are some deep gouges thast im not sure what they are.
    Could this nasty DW im getting be from a bad power steering pump?
    When i took my box off the fluid smelled dreadful.
    Oh and whats a good size hole to do at each end of my crack before i weld it?\
    Any good welding techniques?
    Thanks guys
    Jon
  2. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    wire brush and brake cleaner . this will remove lots of crap. then look over good. if needed post pics we will help ya.
  3. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    what method of welding can you do? i would say to make a groove all the way down the crack and TIG weld it...
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    For good weld penetration you will want to "V" out the crack before welding and make sure it's nice clean metal so it doesn't contaminate. I'm sure a MIG would be just fine for the repair.
    BTW -> You didn't mention it, but I really HOPE you are taking this opportunity to also add the weld-in steering box brace and the triangulating bracket on the rear side. The current crack is your "wake up call"...even a competent repair is likely to crack again if you don't add some additional beef. The steering box area is a notoriously weak area on the K5s.... fix it right, and fix it ONCE. :waytogo:
  5. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    i bought a bolt on brace from a ck5 member so i hopefully will be crackless in the future.
    i only welded one crack, the only one i found. I used a cutting wheel to V out the crack and i welded it, and ground it smoothe.
  6. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Hate to hijack, but I have a question relating to this; has anyone had any success with stop-drilling, as opposed to the 'V' cut?
    Only reason I ask is our structures guys in the AF use stop-drilling to prevent cracks in airframe structures from progressing.
  7. mattm
    mattm Registered Member
    Aug 15, 2005
    9
    phila pa
    would stick welding be alright for this. and what size hole to drill. I 've got the same crack
  8. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Considering the cracks are from the box trying to come off the frame, I think stop-drilling will not be effective.
