i have searched for days!!!
Discussion in 'The Garage' started by wrench6, Feb 18, 2007.
  1. wrench6
    wrench6 Registered Member
    Sep 26, 2006
    5
    Ashland, KY
    Man i have been reading and reading!! If i had done this much studying in school i'd be a genius!!
    Just picked up a 14FF for free today. Problem is i have no idea what it came from. Any easy ways to identify? WMS to WMS?
    If it's a DRW do i need to swap it to a SRW? Any difference?
    Lastly does anyone have a list of D60 WMS to WMS? Need to know what will be closest in width .
    Thanks in advance.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Measure the spacing between the centers on the spring perches. 42.5" is a 3/4 ton axle and 40.5" is a 1 ton axle. Also the van rear axles are the same width as a front D60. If the housing has ribs on the center section then it is 1988 or newer.
  3. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    I.d.
    A GM dealer can identify the axle's ratio and year ,by the 3 letter code stamped into one axle tube near the carrier..supposedly on the right(passenger) side tube,but I have found the codes just about any place on either tubes before...also,the date of manufacture and ratio codes are stamped into the outside of the ring gear..
    Not sure about the answers to your other questions,I'll leave that for those who do know...:crazy:
  4. wrench6
    Sep 26, 2006
    5
    Ashland, KY
    thanks for the info, mines a 4.10 open
  5. wrench6
    Sep 26, 2006
    5
    Ashland, KY
    didn't notice rhie ribs, must be an older one. i'll check the spring pad measurement thanks
  6. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I think the same thing all the time.:D
