I just paid 80 bucks for a CUCV M1009......Needs some help with it
Discussion in '1982-Present GM Diesel' started by 84CUCV, Mar 29, 2003.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I was told it was a roller. I go pick it up and it has a 6.2 400/208 still in it! Of all the luck. I will need drive shafts for it. what I need to know is the top end of the 6.2 was open and no hood. So water is in it. I could not turn the crank. So do I just tear it down and see what I got or should I just pull it? Thanks for the help again! Mike
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    hell, id try throwin some kerosene in the cylinders to get em free. then go from there and see if u can get her runnin /forums/images/graemlins/tongue.gif after all, it was only $80, y nor give it a shot
    NITRO
  3. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Sorry man, if it has sat like that for very long the motor is finished. Diesels are very sensitive to compression. The water would rust the walls in a couple days only. Then when you attempt to start it, it will grind off the rust possibly breaking the rings. At a mininum grinding the rust off will score the cylinder walls and rings.
    If you do attempt to start the engine MAKE SURE 100% of the water is out, otherwise you will hydro-lock the motor. This can bend/break many parts.
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Nitro why should use that? what would it do.Thanks for the help Mike
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If I were you I would just yank it out and take it appart and keep the usable parts but go and get a new short block and put it in.
    You would still have a truck for under 3k with a new engine.
    /forums/images/graemlins/thumb.gif
  6. Crunk_K5_1984
    Crunk_K5_1984 Registered Member
    Feb 5, 2003
    87
    Kosciusko, Mississippi
    If it were me, with as little money as you've got in it, I'd try putting a cummins or perkins in it. Pricey, yes, but most of us have $2000-$3500 in our rigs already, so another $8000 seems too steep, but you might could get away with it /forums/images/graemlins/crazy.gif
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Now that is something to think about Mike
