i keep going through flexplate and starters
Discussion in 'The Garage' started by K-5kid, Mar 31, 2005.
  1. K-5kid
    K-5kid Registered Member
    Mar 24, 2005
    35
    el paso tx
    i tried to shim and i fabricated a bracket for my starter but i makes this bad grinding noise. what could it be. I need to replace my flexplate now and i think maybe the starter. i am stumped
  2. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    Try to make sure you have the right flexplate on it. Maybe someone put one off a 400 or something. Does the motor run rough at all.
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    when does it grind? when you start it, after you start it and it still grinds????
    is the teath on the starter chipped? the fly wheel?
  4. K-5kid
    Mar 24, 2005
    35
    el paso tx
    it grinds when i crank it but then stops and the flex plate could be wrong i am going to rip into it on saturday
  5. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    what kind of bolts are holding your starter on? a stock gm starter bolt is "sleeved" and pretty much centers the starter while u bolt it on. ive seen some people use a regular hex head bolt and the starter will actually walk around on the block- which will cause grinding noise. so make sure youve got the factory bolts. good luck ryan
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive had a starter that did the "walking" like short sub said, but it was with the factory bolts. turns out the nose cone bolt holes were wore.
  7. K-5kid
    Mar 24, 2005
    35
    el paso tx
    yea i am going to try to fix it this weekend so it wouldnt hurt to get new bolts i will give it a shot
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well making a bracket tells me you got something wrong anyways, there is no reason you should be having ot make any bracket for any chevy starter unless you have something like an old iron manual bellhousing and a super old engine block like 55-early 60s or something, other than that no really,
    you should have three threaded holes in engine block for starter noses,
    what engine year and size
    what size wheel
    what crank year and RMS ?
    which starter nose bolt pattern you runnin
  9. teamgerth
    teamgerth Registered Member
    Sep 1, 2003
    57
    Hubbard, OR
    make sure your shim is correct, if it is to loose it will grind and strip the flex plate
