I Keep Snapping....
Discussion in 'The Garage' started by HEAVY METAL, Dec 7, 2005.
  1. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    the passenger side bolt off my 205, 465 adapter, its happend twice now.... i fixed it the first time when i replace my tranny cauze 3rd gear kept poppin out by puttin in a new adapter... just happend again.. any ideas please?
  2. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Helicoil and some new grade 8 bolts?
    Rene
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    do you have the t-case to frame brace?:confused:
  4. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    We have come up with a NP205 side mount kit which is available in either chevy or ford style. We have produced it to be compatible with all doubler applications along with factory setups. Take a look at http://www.northwestfab.com/tcaseacessories.html the kit includes all mounting hardware, urithane bushings, 3/4" fine tread rod for infinate adjustment.
    This should solve all your drive train woes.
    -NWF Crew
    Jordan
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Will this mount work for those of that are using the HAD 205 mounted brake?
  6. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    343
    Fort McMurray, Alberta
    Does anyone have pictures of the 205 brace? My SM465/205 combo only came with a crossmember that the adapter sits on, and it didn't seem right to me that the case would just hang off the end...
  7. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i was having that problem also on my 205. i reinforced the fram and drilled the holes out a bit and put thicker gr8 bolts in. has lasted through 1 wheelin trip now....... so well see
  8. HEAVY METAL
    Jan 10, 2005
    386
    northwest fab.. looks great dude.. i'll have to wait till new year tho.. stupid christ,mas
    Rene...helicoil? whats that bud? i put new grade 8 bolts when i did my tranny.. snapped in the same place as last time.. no i dont have the factory brace....
  9. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    The web page for NorthWest Fab will not load. I am interested in a couple of those because both of my 1-ton trucks are missing the factory transfer case support bracket, but I would like to see a picture of it first, so I can get a better understanding of how it is designed.
  10. HEAVY METAL
    Jan 10, 2005
    386
    Jordan you have mail...
  11. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    anyone got pics of one in a rig?
  12. HEAVY METAL
    Jan 10, 2005
    386
    i will soon :D
  13. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    cool
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I see the pic on NW fabs page. Not sure exactly how that works. The case side would work like a hinge and not really restrain rotation of the drive train. If the frame end is the same orientation (it says "dual urathane isolators at both the transfer case and frame") then it's basically a shackle.
    The other thing is that there is very little clearance between the case and frame rail. Mine is clocked up 2", and on a taller 1 ton frame as well, but I don't think that would fit my truck. I expect it would be below the rail on a stock K5?
    On the other hand, NWF makes some cool stuff and I'm sure they wouldn't produce something that won't work for most trucks, so I may well be missing something...
  15. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    I think for my doubler I'm just going to fab up a support that attaches to the factory mount just above the NWF style one. Its already threaded for huge bolts (5/8"?) so why not just fab up a piece of 1/4" steel plate, with a couple of holes in it... and a piece of tube coming off that which attaches to the frame. Bushing on the t-case end so it can move a little bit.... solid on the frame end so it isn't a shackle. Seems like it would work, and be simple too. The NW fab one looks bling, but I want to use D&D Machine's blingin billet bearing retainers, not sure it would even work with those...
    j
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I question the whole outboard mount approach, but that's been covered before. And in my case, I used those holes to mount a transfer bar pivot for my triple stick inboard shift rail.
  17. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    really? got pics of your shifter setup? That mounting point seems like its a long ways away from the shift rails...
    j
  18. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    No pics. It's just a transfer rod to get behind the 203 range box to the rear shift rail. Just picture the ouboard pivot out there, then a piece of strap stock (transfer bar) going to the shift rail, and a shifter rod hitting the transfer bar at a convienient point. Beats having a side load from an "L" bracket. Look at ORD's, it's fairly similar except they bolt the pivot to the front output.
  19. slowk5
    slowk5 Registered Member
    Oct 14, 2005
    72
    gladstone oregon
    my np 205 isnt even tapped for a factory brace?it lasted 30 years,so i hope i will not have a problem!
  20. NorthWestFab
    Jan 11, 2005
    311
    Canada Eh.
    The photo on our website is more of an one-off prototype we did specially for one customer. We will have the production photo in soon, the bushings are mounted quite a bit higher, and the brace is vertical to resist twist. We have made everything more low profile to better help clear the exhaust. We will also add multiple mount locations for those who have clocked their transfer cases up or down.
    That's exactly the reason we did not use the 2 5/8" holes on the side - not all cases have them! only specifc applications and years were drilled and tapped for them, we wanted a kit that would fit everyones needs.
    The kit unfortunatly will not work with D.D. Machine billet bearing retainers, but we have somthing up our sleeve to solve that.
