I know many of you have this problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Dec 12, 2001.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I've talked to other Chevy guys and it seems that these things tend to leak under and next to the dash on the left side, right in front of the door. Mine has always leaked some, but lately with the tons of rain we've had I have resorted to putting a pail under the dash to catch the water. Does ANYBODY have a clue where it could be coming in? Thanks
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    The rain is comming from the sky [​IMG] It might be leaking from the cowl area or around the window frame
    Some people shouldnt drive anything bigger than their head.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  3. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    The windshield weatherstrip or your cowl is rusted through.
    I live so cal. All my rust is surface rust from the sun burnin the
    paint off my hood &amp; roof ! ! !
    88 5.7 5in lift 35"procomp at's
    700-208-456-3in exh w/flowlowder 10 bolts & some ORD stuff
  4. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Thanks guys but I've checked those things. I was hoping for an answer like 'yea, just plug this hole' LOL. Anybody else with some ideas?
    Mudstud
  5. dyeager535
    26,979
    Have you actually had the windshield OUT? I can't exactly remember the "water route" in the cowl area underneath the windshield, but could it be that water is not being allowed to drain down the inside of the fender area, and backing up in there?
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  6. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I think you'll need a bucket to catch your tears if you take your winshield out. I'm redoing by Blazer and pulled the windshield. I had holes that were over an inch long rotted in the frame. You're gonna have to do some patching. I just took some little strips of sheet metal and put them in place with Fusor body glue. I slip them in from behind and used a magnet to hold them in place. Then with a minimal amount of filler used, you couldnt tell. I could have welded it, but I'm sure I'd burn holes in what I had left and its a tight spot to get a grinder in without touching anything else.
    <a target="_blank" href=http://new.wavlist.com/movies/031/ag-blow.wav>"I ain't nobody, dork."</a>
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have had several that leaked around the windsheild seals. seems like a good place to start
    your right. I don't understand the jeep thing!
