I know this has been asked before, but....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shane74, Aug 12, 2002.
  1. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I remember seeing a post about a 1 piece oil pan gasket for a SB 350. Does anybody have a part number for it? I have asked several auto parts stores around, and nobody has it. Most people gave me the /forums/images/icons/confused.gif look when I asked for it. I am leaving for vacation on Friday afternoon, and I need to get the oil pan sealed up. It dumps oil out by the quarts right now (no exaggeration!) /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif . Thanks!
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Shane if you can't find one,then while your at the parts store smacking the sheeeiiiite outta the lacky , grab some gasket material and make your own.... /forums/images/icons/wink.gif
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The one I found was made by Mr.Gasket. Try a speed shop instead of a regular parts store.
    Rene
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I think the Felpro Permadry Plus is the one piece gasket. The part# is OS34510T.
  5. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I think Milodon lists the Felpro part No. in their website. Check it out.
  6. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Thanks guys. I found it one Summit Racing's website. That part number you have is for a '75 or newer SBC. The part # for '74 and older is FEL-os34509t. There is a difference at the front of the oil pan. it has little horns that tuck up into the bottom of the timing chain cover. That's why I couldn't get the new ones to seal up. They didn't have the little horns. I guess we learn something new everyday! /forums/images/icons/wink.gif
  7. dyeager535
    26,982
    190
    For everyone's benefit:
    Fel-Pro One piece pan gaskets. (as told to me by speed shop)
    OS 34509T 'pre '75
    OS 34510T '75-85
    OS 34500R '86-93
  8. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    THE #%#$#$%^&*$#$#@ THING STILL LEAKS!!! I put in the 1 piece gasket and took off for Montana on time. It leaked like a sieve! I re-torqued the bolts while on the trip too. The instructions say 20ft. lbs on the (4) 5/16 bolts (the two up front at the timing chain cover, and the two back by the rear main) and 2 in. lbs on the rest of the smaller 1/4-20 bolts that run along the side of the pan. Also, you are only supposed to use RVT in 4 spots. 2 up front by the timing chain cover, and two in back where the gasket goes up inside by the rear main. I know the pan isn't bent, but I am running out of ideas. Can anybody help me out here? I really don't want to have to put it in the shop for something as "simple" as an oil pan gasket! /forums/images/icons/crazy.gif
  9. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    Could it be the rear main crankshaft seal or the front one in the timing cover?
  10. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    There is a possibility that it is the rear main, but the leak apears to be coming out from between the gasket and the pan in the rear, not the block and the gasket. That is why this is so frustrating. I'll check the rear main again though.
  11. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Also, I am going to buy a new oil pan and install it tonight. I had a hard time lining up a couple of the bolts when installing it, so I am wondering if my pan is bent?? It was almost like it was too wide for the block?? I don't think this is normal, but since it was a minimal leak to start with, I didn't think about it. I hope that the fel-pro gasket is re-usable....I'll find out!
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It is re-usable.
    Just replace your rear main while you're there...and use non-hardening sealant on the rear main cap.
  13. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Good luck with the pan gasket .I went though 4 of them trying to get the fawkers to seal and on the 4th one it finally sealed /forums/images/icons/tongue.gif then after I did that I put the oil plug in and then put the oil in and the fawking oil plug started to leak ( the treaded plug weld broke ) so it is leaking where I go for now because I am not going though that dam oil pan gasket again....mike /forums/images/icons/smile.gif /forums/images/icons/smile.gif /forums/images/icons/ooo.gif
  14. dyeager535
    26,982
    190
    Sorry to hear it, new pan yet?
    Hopefully that solves it, should be a "perfect" bolt hole line up in my thinking on that pan issue, no "tweaking" required.
  15. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Well, here's a totally cunfuddling one for ya... We got back from our trip, and ever since I have not been pulling the trailer, It hasn't been leaking?? /forums/images/icons/confused.gif I have great oil pressure on start up, but as soon as it warms up and the oil thins out a bit, the pressure gets real low at idle (around 7-10 psi) as soon as I step on the gas it jumps up to about 40 psi. There is no strange knocking, no oil drips when I shut down, and the pan is full. I know I am burning some oil (the poor ol' 350 has at least 300K on it) but there is nothing where it shouldn't be. I haven't been able to replace the pan yet (hopefully tonight) and I'll see if that makes a difference in the warmed up oil pressure at idle. This is wierd...I am totally cunfuddled by this one. /forums/images/icons/confused.gif /forums/images/icons/tongue.gif Time to put the 454 in! /forums/images/icons/grin.gif
  16. dyeager535
    26,982
    190
    Yeah with that many miles, wouldn't be too disappointed with that kind of PSI at idle, but I'm surprised you get that much as the RPM's increase. Thats good that you have so much PSI at least.
    Not sure on that leak thing, I've never heard of an oil leak get better by itself! : ) Hopefully it doesn't come back.
