I lost it ,searched but nada (its a pic i need)
Discussion in 'The Garage' started by sapper, Nov 16, 2004.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Trying to find a picture someone had of the bottom of there rig after clocking a 241. It was completlly flat and plated from framerail to framerail. Anyone have this, TIA
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    /forums/images/graemlins/whistling.gif
  3. sapper
    Jul 11, 2001
    3,052
    NoVa
    THATS IT BABY!!!!!!!!!!!!!!!!!!! I might be sending you a pm or two this winter, Thanks /forums/images/graemlins/thumb.gif
    Hey we were both SSgts in iraq, what a small world
  4. Esteban86K5
    3,712
    Bakersfield, CA
    No problem!!! /forums/images/graemlins/waytogo.gif
    BUt i have to admit, I kind of regret doing it. After all that hard work I put into it, I have yet to use the damn thing. It's tucked up so far that the skidplate hasn't even been touched. I'm thinking of dropping it about 6 or 7 inches just so i can get some good use out of it and put some nice gouges in it. /forums/images/graemlins/histerical.gif /forums/images/graemlins/whistling.gif
  5. sapper
    Jul 11, 2001
    3,052
    NoVa
    sounds like a problem i would like to have. Were you able to do that from just the clocking ring or is there some additnal mods to make it work?
  6. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    hey esteban, how about a picture of that front drive shaft /forums/images/graemlins/whistling.gif
  7. Esteban86K5
    3,712
    Bakersfield, CA
    Well I did raise the entire drivetrain up about another inch. And the mods that i had to do are:
    Cut the floor board
    reroute exahaust
    extend front driveshaft
    shim the front axle for better angle
    I think that was about it. I raised the drivetrain up just so i could put the skidplate flat with the framerails. If you don't raise the drivetrain then it will be about an inch or 2 lower than mine. I run a 2" body lift and I still needed to cut the floor boards out so that the T-case would rub them.
    And Smokey, I forgot what pic of the front shaft you wanted? Sorry /forums/images/graemlins/dunno.gif
  8. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    no problem, when ever you have an chance you can pm it to me on the SCBD forum /forums/images/graemlins/waytogo.gif
  9. Esteban86K5
    3,712
    Bakersfield, CA
    What was the pic you wanted? /forums/images/graemlins/doah.gif
  10. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    Of your drive shaft angle and how you extened it.
    Just trying to get everthing figured out, before I do this mod to my burb next month.
  11. Esteban86K5
    3,712
    Bakersfield, CA
    Oh yeah I remember now. The extension is nothing more than getting a piece of tubing/pipe that is a little larger than your existing one, then cutting it to the length you need your shaft to be. Then you cur your shaft in half and slid it in from both sides and weld it up. Sure it's not balance and all of that but I'm not into high speed runs in $wd so all is good. /forums/images/graemlins/waytogo.gif
  12. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    cool thanks /forums/images/graemlins/waytogo.gif
  13. Esteban86K5
    3,712
    Bakersfield, CA
    O.K. I just went outside and took some pics of my junk. Don't make fun of the drivers side exhaust. It was something i threw together right before a run and haven't replaced it yet. To be honest I probably won't replace it untill it breaks. /forums/images/graemlins/whistling.gif
    And it's filthy from my last run too. I took it off the trailer and parked it and haven't looke at it since. /forums/images/graemlins/shame.gif
  14. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks esteban /forums/images/graemlins/waytogo.gif
