I messed up my 14bolt's pinion yoke
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Feb 7, 2001.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    I messed up my 14bolt\'s pinion yoke
    I snapped off one of the driveshaft bolts in the yoke. I've tried an extractor, but they keep breaking. Tried drilling it completely out, but my electric drill just isn;t able to do it.
    What about getting a bolt to go through the hole and putting a lock washer and a nut on the end? Would it throw the driveshaft balance out of whack?
    I'm sure a new yoke is a good $80 or more, plus there is the crush sleeve to mess with.
    -- Mike
  2. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    Bay City, MI 48706
    Re: I messed up my 14bolt\'s pinion yoke
    I had the same problem with my front Dana 44. I tried an extractor and it broke. I decided to get a new yoke and I got it for $65 at the dealer. I rented a puller, put the new one on and tightened down the bolt. No problems and its been over 4 years. But, to make sure that you do not over tighten the pinion nut simply mark the nut and the top of the pinion with a marker. Then when reinstalling tighten the nut until the marks line up.
    74 Blazer
