I need a FanCluch but don't know>>>>
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burt4x4, Aug 14, 2001.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I need a FanCluch but don\'t know>>>>
    Ok alot of talk about cooling but I have one more question!
    I have no experiance at all when talkin FanCluches!
    I have heard/read allot of advantages to running a cluch so I'm gonna goforit.
    What brand should I buy?
    Does any fan bolt onto a cluch or does the fan have to be made for that cluch?
    Summit sells a cluch for 40 bucks. Does anyone have this one? If so what kinda fan is bolted to it?
    Oh ya I have a short style water pump, does that matter??
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: I need a FanCluch but don\'t know>>>>
    You have to run a regular fan (ie not a flex fan) with a fan clutch. You could just get one from a J/Y.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  3. Burt4x4
    6,854
    Well the J/Y around my home are well full of junk!! No Trucks that have didlly squat on them. plus I want new for reliablity...
    So you cannot put a flex fan on one of thease cluches??
  4. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    No, the clutch will not bolt up to the fan. I read an article a while back in an issue of carcraft that had acampaisions of different cooling fans and how they afftect horse power. if i remembe correctly, the second best fan they tested was a clutch fan with a flex-a-lite 5655 thermal clutch. it goes for a little more than $60 and you can also get a flex-a-lite fan to fit the clutch for another $30 but that is not a "flex fan." The first best fan they tested was the flex-a-lite black magic electric fan
    Check out my 73 K5 <a target="_blank" href=http://members.theglobe.com/xnoahx/73k5.htm>http://members.theglobe.com/xnoahx/73k5.htm</a>
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Don't you have an electric fan? Why are you going to go with a clutch fan? Or are you going to use both?
  6. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    A good fan clutch will free up more power than a flex fan. But i dont know if they pull more air
  7. Burt4x4
    6,854
    Yes i am gonna run both! I have the BlackMagic M150 running solo right now and it has allways kept my 350 cool, until this summer.
    I think my engine mods, added weight, lower gearing, etc... has added more load to my motor and now when my rig is working hard up thoes long hill trails the temp gage starts rising and doesn't stop until I kill the motor at 230.
    So I am going to a 4row and adding a cluch fan and will use the M150 for thoes hot working situations...
  8. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    I bought a clutch from summit, works fine. I got an aluminum universal 17in fan from AutoZone. It comes with a couple of different bolt patterns drilled in it so it will work on different clutches. Pulls alot more air than stock. I am happy with it.
  9. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Instead of going for a new four core rad you should look at a high capacity 2 row. After my old rad let go, I was shopping around for a new, bigger one and my mechanic told me about this fancy 2 core. He swore it would cool as good as a 3 or 4 core- I was pretty skeptical!!!!! He promised me that if it didn't do the job he would pull it out and replace it with a 3 core for FREE!
    Let's just say I still have the highflow 2 core in the truck. I use my K5 for lots of towing in the summer and for the first time in 4 years of towing, my fan clutch hasn't engaged once(even when it was 32' Celcius), and I tow over some pretty nasty passes up here.
    <font color=red>PHOTO ALBUM-</font color=red> <a target="_blank" href=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</a>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  10. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    So.....what kind of radiator is it and how much $$ are we talking??
    <P ID="edit"><FONT class="small">Edited by 90blzr on 08/14/01 05:44 PM.</FONT></P>
  11. Can Can
    15,552
    136
    I'm not really sure who the manufacturer is........I seem to remember paying around $280 CDN for it. If you really want to know I can call my guy tomorrow and ask.
    I just went and checked the truck. I'm not sure if this helps at all but the rad is made by SPI up here in Canada. I'll try to get some more info tomorrow.
  12. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Thanks that'd be great!
  13. dyeager535
    26,976
    Someone mentioned a STOCK AL GM replacement radiator too..an AL radiator will cool better than a comparable copper/brass one, so that would be a good option too. Aftermarket has to be making them as well as GM, so cost should not be bad. (I'm not talking Griffin radiators, there are stock aluminum style ones out there I'm sure)
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
