I Need a lesson in Low-Temp Thermostats
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lance, Jan 30, 2004.
  1. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    A couple of members have offered up some advice on why my truck seems to be stumbling / starving for fuel at idle and when under load. (You can read about the whole sorted mess about the K5 in the "Bloody Knuckle" if you are so inclined.) Based upon the items that have been replaced (fuel filter, plugs, wires, cap, rotor button, MAP sensor) I was told that if I have a low-temp thermostat, this may be casuing me my problems. What I don't necessarily understand is why the low-temp thermostats would cause this reaction. I'm guessing it has something to do with timing advance or something similar but, I'm really lost. /forums/images/graemlins/1zhelp.gif
  2. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Looking at your profile, Your truck being a '90, they were designed, I beleive, to run in the neighborhood of 205-210, due to emmissions and stuff... if you are running a really low thermostat then it could be the temp is not up to where the computerr is programed for, thus causing erratic data for the system, also if you have vaccum ports they are most likely built to open a certain temps that you are now not reaching which could cause the vaccum system to also be erratic.
    Thats my take... I'm no GM mechanic but hopes this helps..
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    If it runs too cool the system won't go into closed loop.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Check my reply today on your original post.
    I explained why /forums/images/graemlins/thumb.gif
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    rif hit it.
    Aftermarkey computer proms want you to run a lower T-stat, But the prom will accept that. Stock EFI won't.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Too low of a t-stat keeps the engine in "cold mode" or as others are saying Closed loop. It basically tells the computer it still cold and in turn is giving the engine more fuel. This does work however on sports cars, i had an Iroc i did this to, used a 180 t-stat and lower temp fan switch, it ran faster, but in turn, used more fuel. As far as starving/stumbling, how many miles are on it, if near or over 100k and never changed the fuel pump, it may be losing pressure, i had this happen to my 89 Burb, same type of stumbling just no power at all, but idled fine. 100k is about the average life of a stock electric in tank fuel pump. Check fuel pressure and always run the recommended t-stat for computer controlled engines unless looking to use more fuel for more power. Just my .02 cents
    T.J. 4xcrazy
  7. Lance
    Mar 4, 2002
    606
    Birmingham, Alabama
    Thanks for all the input everyone. That's basically what I figured.
    As for the problem, it was in the fuel pump / strainer. Replaced them both and it ran perfect.
