I need a little help here at work on bolt size and length
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Leadfoot, Jun 5, 2003.
  1. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I'm looking to order new bolts to install my rear springs in the 80 K20. Does anybody know the size and length of the bolts used to hold the rear springs as well as the shackle bolt. From memory I'm thinking 9/16" (or maybe 1/2") by 4.5" fine thread, but it's been a while. I want to order online today, so I won't have a chance to measure mine. Anyone know???
    TIA
    Chris
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Right size (9/16). Not exactly sure on length or thread pitch. 4 1/2 inch does sound correct. Order the grade 8's, but you already know that, along w/ Nylok nuts.
    John
  3. Leadfoot
    Nov 28, 2000
    3,112
    Thanks,
    Yes I am going to use Grade 8 Zinc plated fine thread, but instead of the Nyloc nut I use "Top Lock" nuts. They are the kind the factory uses. They are flat like a regular nut on the face and tapered at the top. They are also machine crimped (miss-shapened) at the top which provides the locking aspect.
    Thanks for the heads up though, Nyloc would be my second choice if these weren't available.
    If anyone can confirm the length (if your rig is readily available), it would be greatly appreciated.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i dont like those top crimp style nuts. here is why.
    they hold great, as do the nylon insert style. BUT i would rather replace a nut after 2 or 3 times of removing it than the bolt. the crimped nuts eat the bolt away the first time or 2 of being installed. nuts cost less than bolts.
    Grant
  5. Leadfoot
    Nov 28, 2000
    3,112
    Very true about it eating the bolt, but if they do get removed (which hopefully they won't for awhile), I will replace them anyway. I'm anal like that, and the fastenal down the road gives me great prices (high volume discount.......as I have gotten work to buy all their fastener's there /forums/images/graemlins/blush.gif).
  6. Grim-Reaper
    7,385
    Atlanta
    Just went and measured. 4.5 on my half ton for the rear .
