i need a new front drive shaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86badass, Jan 13, 2002.
  1. 86badass
    86badass Registered Member
    Jan 2, 2002
    17
    port huron michigan
    i need a new NP 208 front drive shaft. i can move mine in a inch in every dirrection. anybody know i cheap place to find one.
    i drive:
    1986 Jimmy 4X4
    brown and tan
    new 350 engine
    no rust
    31 inch tires
    re-wired taillights (myself)
    i have bad vibrations!!!!!
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I have one I was gonna get shortened for my np205 swap, but the welding shop said the splines were worn out. If you want, I'll see if I cant go over there and pick it up. He said it be like 70 bucks to fix and it needs a new front u joint. You could have it for shipping.
    If you want tog balls out you can get a new shaft from high angle or tom woods but thats heavy cash. I say try the junkyard.
    1978 K20 - 355ci, np205, th400, D44, 14F, 7" of Lift, 36 x 14.5 TSL Radial
  3. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    If you want to go balls out you can get a new shaft from high angle or tom woods but thats heavy cash. I say try the junkyard.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Mine does that too. Any way to rebuild them, or is it cheaper to get a new one made? thanks
    90K5
