I need a new trans maybe
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jacksprat1599, Apr 17, 2004.
  1. jacksprat1599
    jacksprat1599 Registered Member
    Dec 13, 2003
    99
    Austin Tx
    I think its dying.It appears to be leaking from the pan and doesn't want to shift out of first until obout 25 mph and then does so with a bang.Who makes a good replacement for the 700r4 if I need one.Oh,this one has 160k on it.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sound just like the first time my 700R4 went out. I would say find someone local with a good reputation for building heavy duty tranny's and pay to have a good 700R4 built with all the right parts. Or Bowtie Overdrives makes some good trannys too.
    I had mine built local. It was built heavy and has a 2yr/24K warratny. If I wouldn't have gotten the warranty I would have went with Bowtie OD's.
    You might also be able to get a GM 700R4 for that too. Check your local dealer. They will be expensive but they carry a 3/36 warranty or 3/50 warranty. I don't remember which.
    A good 700R4 isn't going to be cheap. Bowtie OD start at $1100 plus shipping. I paid $1600 for mine installed with the warranty.
    $1600 was the going rate for a built 700R4 in Phoenix (installed) $900-1100 without install.
    Harley
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd be thinking sm465. /forums/images/graemlins/deal.gif
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    or at least thinkign th350 since it will go in place of the 700r4 about 95% directly, and they are common to find in good shape still /forums/images/graemlins/laugh.gif
  6. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    it is a daily driver suburban not a rock crawler so I would like to keep the overdrive and isn't the th350 a weaker trans than the 700.
  7. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    The 350 and the 700 are about the same weakness. Like was said before, you can get a bowtie overdrive with a great warantee for not too much more than a local rebuild. Just make sure you get a shop with a good reputation if you let someone local do it.
