I need a photochop....
Discussion in 'The Lounge' started by mikey_d05, Dec 4, 2005.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    In the past couple months I've learned my K5 is kinda wide on the trails around here. If I can get my garage wired for 230 before Christmas I'll have a functional welding setup. My grille is hanging out at the garbage dump and my fenders are slightly wrinkly...this all leads to one conclusion....a narrowing job :D
    Anybody want to try their hand at photochopping it? I'm lookin at about 10" off each corner and would kinda like to envision it before I start hacking.
    Jiminy...I know you're out there. :D
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Sumtin like 'dis?
  3. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Nope, I've already got the rear taken care of.
    I'm just looking for some bored soul to simulate a chop job on the front with the flames and everything. I can't get to cutting for at least two more weeks and I'm going into withdrawl.
  4. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Not me. Just simple re-coloring is all I can do with picture programs. Otherwise I'd be posting hacked up InuYasha pics all the times of InuYasha and co. doing stuff that only custom photochopping could produce.
  5. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I'll do it, get me a pic and exact details
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Great photo there!!! :waytogo:
  7. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    WHOOOO MEEEEEE? Bwahahahaha, I'll be happy too. :tongue1:
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I'm planning on roughly 10" of chop on each side. 20" total give or take a little. Plans might change depending on where everything would line up well. Basically, to to the inside of the factory headlights or where the vertical chrome strip was when the grille was still on it. Name your poison out of the pics below. Obviously the winch and mount are staying put so I'd prefer one of the action shots with the winch mount be chopped but whatever you want to do works. Thanks guys. I know you've all seen a hundred rigs narrowed but you really don't know how it's gonna come out until you see it.
    :doah: It used to look so pretty.
  9. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Ok, let me see what I can do, prepare thyself young one.
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Haha, if you want a different pic just check out my photobucket account.
    Thanks man, I'm kinda nervous about how it'll look. I want to do it but I've messed up the lines of enough with trees and my sawzall already. :doah:
  11. Inu-Hanyou1776
    Oct 1, 2005
    1,345
    Murphy, NC
    jiminy be sure to post up your results for everybody see! :D
  12. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Here's a quick one, not exactly perfection but you get the general idea. Before & after. Made a few changes - this is closer.
  13. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Thanks Jiminy, much better than I could have done. I wonder how much the fenders will pull back when I bend them in.
    What am I talking about...I haven't even called the electrician yet. :doah:
  14. Cricket
    Nov 29, 2004
    8,224
    Colorado
    You'll probably lose 5 or 6 inches, that would be my guesstimate. I extended them a bit in the pic, let me see if I can pull them back in a tad.
    Well crud, looked worse. The problem with the picture manipulation is changing angles and perspective. These camera editing programs aren't like a Cad/Cam. More of a copy-paste-rotate so you lose size relation easily.
    I think what you see there is pretty close. If you need to extend the fender you can always tig or tack mig in a section from a spare. There are plenty of banged up ones in the salvage yard.
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    You don't have to go and re-work it man, I'm just wondering for the sake of my cowl and wipers and radiator. It was an out loud thought and not a criticism of your chop.
  16. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Oh I didn't take it as a criticism, just like to get as close as possible for you. :D I would think you cowl & wipers would be fine being up close to the windshield. You may have to end up putting in a different radiator if you want to go that far in but I bet you could just squeak it.
  17. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    if i remember right i think we took about 4 inches off the back of my hood to make it fit when the fenders pulled back the core support...
    just look at everyones pics of their narrow jobs.. its real straight forward, and easy as hell...
    itll look fine man... ;P
  18. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I'm probably just gonna take off the cowl and cut the hood to fit. I'll probably just skin the hood and fenders and brace the core support to the firewall.
    Should be easy, but I have a way of complicating things. I already regret cutting it up after the original round of buildups, but it's a hardcore wheeler now and there's no turning back, might as well make it function as well as possible.
  19. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    good luck man... anxious on the progress pics...
  20. spongeidys
    spongeidys 1/2 ton status
    Jul 6, 2005
    2,566
    Dillion, CO and Palmerton, PA
    anyone have any info on the truck that dontoe posted?
