I need a Q-jet.. where can I get one?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillyBob, Jul 26, 2001.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    My Q-jet is still running rich. No matter how much I have had people try to tune it, it's still screwed up. I think it may be because it's missing some of the vaccum lines due to the engine replacement a couple of years ago. Is there any way to get rid of these unneccesary vaccum lines?
    I know the thing probably needs a rebuild too. I need to know where I can get another one since I can't just take apart my Q-jet for a rebuild cuz my 84 is the only truck I have running now. Everyone tells me to get away from Q-jets cuz they're harder to tune for custom applications. But, I wanna stay with a Q-jet cuz it seems to be a really good carb for my truck. If I have to, I'll go to an edelbrock carb, but that's only if I run out of options.
  2. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    I bought one off of eBay before. Just do a search for quadrajet.
    1986 K5, New GM 350, Edelbrock Intake, K&N Air Filter, Flowtech Headers, Dual 3" Exhaust, 33" Pirelli Scorpion AT, 700R4, 3.42 gears
  3. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    go to the bone yard. Aound here you can find em for $20 if you look. Can't hurt to try.
    Mike
    You call that dirty!?
  4. BillyBob
    Feb 23, 2000
    557
    Dumont, NJ
    Ebay is kinda iffy to me. I'm afraid that I may be screwed over with a crappy carb. Is it really worth going there to get one?
    <a target="_blank" href=http://billybob87k5.50megs.com>Homepage of Porky & Stinky</a>
    Billybob, the REAL <font color=red>Bionic Redneck</font color=red>
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
  6. johnny reb
    Mar 6, 2000
    326
    Pittsburgh, PA
    I got mine from eBay for $20. I rebuilt it when I got it and I couldn't be happier. As with buying anything on eBay, just be careful who you're dealing with.
  7. dyeager535
    26,982
    191
    You can pull off all vacuum lines and plug them, and it will run fine. Only thing you will need to keep hooked up is the secondary pulloff, which is the one that comes out of the passenger side front of the carb, at a downward 45 degree angle, basically pointing towards the passenger front wheel.
    If its running rich, it may be as simple as a stuck/maladjusted float or power piston being stuck in the bore. If not a carb with electrical plugs (besides the choke, if electric) you can remove the top 1/3rd of the carb with it still on the vehicle, and check both the power piston and float level. Rebuild kit will come with the gasket you will need, and will run you $20 or less typically.Will have the float height checker with it as well. I'd have to recommend getting Doug Roe's book "rochester quadrajets" You'll learn a lot about these carbs operation. They aren't as complicated as people make them out to be.
    Dorian
    My tech/links page: &lt;a target="_blank" href=http://www.dorianyeager.com/index2.html&gt;http://www.dorianyeager.com/index2.html&lt;/a&gt;
    No anti-theft measures on your truck? No pity when its stolen
  8. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i feel your pain. i went through 3 of them on my 82.
    Engineers up!
